Go Back   Vista Forums > Vista Forums > Drivers
Vista - no sound on vista home editon 32 bit
Old 02-16-2009   #1 (permalink)
vista home premium 32bit
Hi to all!
I just join in this forum in the hope that somebody could help me. I just recently install vista home edition 32 bit on my asus p5gl mx motherboard. Unfortunately, there isnt any sound that will come out from my altec lansing 151i speaker(5.1). I tried to install the audio driver from the cd that comes with the motherboard but vista would say that the hardware doesnt support the software.
It used to function well on my windows xp sp 3. Now, I dont have any sound at all. The os showed the volume control panel and it wasnt muted but to my surprise there isnt anyt sound coming out from the speakers.
Could you please help me out on this matter.
thanks in advance!
Old 02-16-2009   #2 (permalink)
Vista Ultimate x64
Re: no sound on vista home editon 32 bit
yuri welcome to the forums.
No promises but there is a Vista compatible driver linked here last post with a link to Asus' FTP server),
Audio Problem - SoundMax ADI1986A - Microsoft Windows Vista Community Forums - Vistaheads
Old 02-17-2009   #3 (permalink)
Vista home premium 64 bit
If this solves the problem yuri, please let us know so this thred will help others.
Old 02-17-2009   #4 (permalink)
i installed it on my vista home edition 32bit but unfortunately when i restart the computer, it switched back to high definition audio device and there wasnt any sound at all. It made a sound before i restarted and it only supports two channels. Is there a 5.1 on this driver?
I really need your help and thanks for the reply!
Old 02-18-2009   #5 (permalink)
I have had a good look at the web and can not find any drivers for the onboard audio.
Have you tried an Audio card and use that. It will diable the onboard sound. This way you will get sound and it will be alot cheaper than a new motherboard.
Poor Sound under Vista Home Premium Vista General
vista 64 home premium no sound Media Center
No sound after upgrading from Home Basic to Home Premium Vista hardware & devices
sound recorder-Vista Home Premium Vista General
Upgrading from Windows XP Media Center Editon to Vista Vista installation & setup
