| vista home basic 32 bit | TSST Corp TS-H492c driver problem i have an eMachine t3604 and am having problems with the dvd/cdw drive. it is a TSST Corp TS-H492C. it has worked for over a year and now when i look at the Device Manager there is a yellow exclamation mark in front of the drive. i have uninstalled and re-installed the driver and get an error code 37. i installed another dvd/cdw drive and had the same problem. the other drive is a different manufacturer and model. any help wll be appreciated. |
| vista home basic 32 bit | Re: TSST Corp TS-H492c driver problem I saw all the other dvd/cd problems that sounded like mine. i downloaded the CDgone.Reg program and it fixed the problem. thanks |
| tsst corp dvd code 39 | Drivers | |||
| TSST corp CDDVDW TS-L632H ATA device | Drivers | |||
| TSST Corp DVD+RW TS-H653 A - Driver Issue | Drivers | |||
| Problem with TSST Corp CDRW/DVD TSL462D ATA Device | Drivers | |||
| Problem with TSST corp DVD+ -RW TS-L632D ATA Device | Vista hardware & devices | |||
