| Vista Home Basic x64 | Logitech G5 Mouse Problem Hello, I have had a problem with my Logitech G5 mouse since i got my new Computer. I did not have this problem on my old Computer (Vista 32bit) and now, it randomly freezes, and then works again. My specs: CPU: Intel Core 2 Duo @ 2.77Ghz Bundkort: P5N32-SLI Premium RAM: 2gb Corsair XMS2 xtreme 800mhz Graphic: Geforce XFX 8800 ULTRA 756Mb Dedikeret Windows Vista 64 bit Home Basic. I have tried it on another Computer which is running a bit lower on specs, but runs vista 32bit, and theres no problems, what so ever on there. I have tried to reinstall the drivers (Also for Windows Vista 64Bit) from logitechs homepage, and reconnect the mouse in a different usb port, but no luck yet. i hope someone knows how to fix this, or have a suggestion, as it is driving me crazy, to see the mouse freeze constantly. by the way, i have checked the speed, and it runs at 500hz Thanks |
| Vista Ultimate x64 | Re: Logitech G5 Mouse Problem Are you using logitech setpoint software? Did you tried an other mouse on this pc ... Is the mouse turning off (the leds don't light ) or just hangingi didnt have any problems with my g5 till now (and i hope it stays so^^) |
| Vista Home Basic x64 | Re: Logitech G5 Mouse Problem Yes, i am sure it is Logitech software, and im really suprised too, Because it worked perfectly on my other computer. I will try use another mouse, and see if theres any problems ther now. |
| Vista Home Basic x64 | Re: Logitech G5 Mouse Problem Hey, No worries now: I have been thinking alot about the problem , and found a solution:Set the Mouse rate down. It works fine now, and theres no other problems.. |
| Vista Something 32bit | Re: Logitech G5 Mouse Problem Hey, I've got the same problem, and the leds just turn off when the mouse freezes, and I've tried the softwares I could find but nothing helps, where do you configure the mouse rate? |
| | #6 (permalink) |
| Vista Home Premium 64bit SP2 | Re: Logitech G5 Mouse Problem ![]() Possibly if your rig is a little underpowered a high report rate could couse a problem |
| Logitech MX 310 Mouse | Vista hardware & devices | |||
Logitech mouse | Drivers | |||
| logitech mouse | Vista hardware & devices | |||
| Logitech Optical Mouse | Vista General | |||
| Logitech mouse | Vista General | |||
