| Vista 32b | Audio driver problem . Hello, im pretty new here.. and i need some help with my audio driver. (I'm sorry for my bad english) Okay so my OS is vista 32b, I format my PC and then i put in the disk with the audio driver which i recieved when i bought my computer, and it failed. It says ..your audio driver files do not support your computer hardware... i tried to download some latest drivers from the internet but they whole did the same error :X. I'll be glad if u can help me get an audio driver. ![]() Here some information ¬¬¬ Motherboard ID 64-1216-000001-00101111-081407-Intel-BW$A0483035_BIOS DATE: 08/14/07 20:46:02 VER: 08.00.12 Field Value Motherboard Properties Motherboard ID 64-1216-000001-00101111-081407-Intel-BW$A0483035_BIOS DATE: 08/14/07 20:46:02 VER: 08.00.12 Motherboard Name Asus P5B Deluxe Front Side Bus Properties Bus Type Intel AGTL+ Bus Width 64-bit Real Clock 333 MHz (QDR) Effective Clock 1333 MHz Bandwidth 10665 MB/s Memory Bus Properties Bus Type Dual DDR2 SDRAM Bus Width 128-bit DRAM:FSB Ratio 1:1 Real Clock 333 MHz (DDR) Effective Clock 667 MHz Bandwidth [ TRIAL VERSION ] MB/s Chipset Bus Properties Bus Type Intel Direct Media Interface Motherboard Physical Info CPU Sockets/Slots 1 LGA775 Expansion Slots [ TRIAL VERSION ] RAM Slots 4 DDR2 DIMM Integrated Devices Audio, Dual Gigabit LAN, IEEE-1394 Form Factor ATX Motherboard Size 240 mm x 300 mm Motherboard Chipset P965 Extra Features [ TRIAL VERSION ] Motherboard Manufacturer Company Name ASUSTeK Computer Inc. Product Information http://www.asus.com/products.aspx?l1=3 BIOS Download http://support.asus.com/download/download....SLanguage=en-us Driver Update http://driveragent.com?ref=59 BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40 ¬¬¬ oh and i dont really know if its importent but when i bought my computer i had ..sound¬max.. audio driver . |
| Vista Ultimate x64 | Re: Audio driver problem . deaps welcome to the forums. You didn't say where you downloaded the drivers from but it sounds like you didn't go directly to Asus. Go here, ASUSTeK Computer Inc. click on Downloads, select your OS (Vista 32 bit in your case), then select the drivers you need. |
| Vista 32b | Re: Audio driver problem . Still same probelm when i tried to install them.. ''your audio driver files do not support your computer hardware'' |
| Vista Ultimate x64 | Re: Audio driver problem . Did you install the chipset driver first? |
| Vista 32b | Re: Audio driver problem . Yes. |
| Vista x64 Audio Driver Problem ! | Sound & Audio | |||
| Realtek Audio driver problem | Sound & Audio | |||
| audio driver problem | Vista installation & setup | |||
| Audio problem with Realtek driver | Vista hardware & devices | |||
| Audio driver problem | Vista General | |||
