Go Back   Vista Forums > Vista Forums > Drivers
Vista - scsi scanner help
Old 05-16-2009   #1 (permalink)
vista ultimate x64
scsi scanner help
Hello,
I am currently looking for help on having my 4p scanjet scsi scanner work.
I recently switched to vista 64 upon new hardware
The scanner with the adaptec 2940u were working perfectly with vista ultimate 32
Currently windows recognizes the scanner
The card is under the emulated driver (solution I found on these forums)
after copying over deskscan II and moving files from vista 32 to 64 without problem image programs find deskscan but somehow there is no communication with the scanner.
if one goes to the device manager it reports scanner and card working fine. However if one checks the scanner's profile it says unavailable.
anyone have an idea of what the problem is? Should I give up on hps software and use vuescan? or is it the scsi card?
If its the card's compatibility which is a good card for the scanner?
any help is greatly appreciated
Thanks
Re: Does some one knows a good virus scanner that is just a scanner? Vista General
It Lives! Old HP SCSI Scanner on Vista x64 Drivers
Vista with an HP5pse SCSI scanner Vista print fax & scan
Scanner is installed but Scanner Center says no scanner installed Vista print fax & scan
