| Windows 7 | Driver Power State Failure BSOD Hi all, I've been receiving a Driver Power State Failure BSOD after shutting down/restarting my machine since yesterday. I just installed the Windows 7 RC1 but noticed people have helped out with this BSOD error on these forums before. My shutdown is taking around 20 minutes before crashing with the BSOD. How do I find out what is causing the error and fix it? Should I post my minidump? Thanks. |
| Vista Ultimate SP2 x64 : Seven Ultimate x64 | Re: Driver Power State Failure BSOD Post the dump, it may point to a cause however the symbols for Seven aren't available yet, so it may also be inconclusive. |
| Vista Home Premium 32bit | Re: Driver Power State Failure BSOD Greetings, I have an HP Pavilion dv4 running Vista Home Premium 32 and encounter BSODs at random times, the most recent time with a "Driver Power State Failure". HP support has been unable to solve this. I've unplugged all ancillary peripherals (keyboards, monitors, etc.) to try and isolate the issues. The laptop can go for several days even weeks with no errors, then poof. The BSOD seems to always have an 0x0..07F code associated with it. This is for business use, so I'm in dire straits... Thanks for any help out there! |
| Vista Home Premium 32bit | Re: Driver Power State Failure BSOD I'm running Vista Home Premium 32 - not Seven. So I'm new to this... How do I post the Dump? Thanks for your help! |
| Driver Power State Failure.... | Drivers | |||
| Driver State Power Failure | Vista performance & maintenance | |||
| Driver State Power Failure While installing Vista x64 Ultimate | Vista General | |||
| Rivatuner64 BSOD Power State Failure | Vista General | |||
| driver power state failure | Vista hardware & devices | |||
