| Member | Driver problem My computer was going through its scheduled maintenance and an error was found that said "a driver problem was detected on flash reader" what does this mean, And it gave me the option of re-installing the driver or restoring the original driver. Which one should i use. I'm afraid i'll uninstall something i won't get back. Info on my computer Model IQ504 Windows Vista Home Edition x64 4.0 GB |
| Member | Re: Driver problem What happens if i uninstall the flash reader??? How will it affect my computer?? |
| Gamerholic | Re: Driver problem Hello jen004, You can un-install the flash reader and re-install it. What flash reader is it ?. |
| Member | Re: Driver problem Its for Portable Devices...How do i re-install it once its un-installed? Is this something i need? |
| Gamerholic | Re: Driver problem When you install a flash reader it will install the driver it needs, or it will come with a driver. You can restore this driver with no ill effects, and if you do happen to un-install something it's not a problem as you can re-install it. Hope this helps, good luck. (If you have any problems get back to me). |
| | #6 (permalink) |
| Member | Re: Driver problem When you install a flash reader it will install the driver it needs, or it will come with a driver. You can restore this driver with no ill effects, and if you do happen to un-install something it's not a problem as you can re-install it. Hope this helps, good luck. (If you have any problems get back to me). Thank you, i will try it.. |
| | #7 (permalink) |
| Member | Re: Driver problem When you install a flash reader it will install the driver it needs, or it will come with a driver. You can restore this driver with no ill effects, and if you do happen to un-install something it's not a problem as you can re-install it. Hope this helps, good luck. (If you have any problems get back to me). Thank you, i will try it.. ![]() |
| | #8 (permalink) |
| Gamerholic | Re: Driver problem Glad you got it sorted. |
| I have problem starting up Vista - problem with driver | Drivers | |||
| for user that have the driver problem driver. How do we clean inst | Vista installation & setup | |||
| Another problem with CD/DVD driver | Vista hardware & devices | |||
| RE: Vista install problem - Failed to add driver package into driver s | Vista installation & setup | |||
| WLMd crashing problem, possible problem with Vid. Driver?? | Vista General | |||
