Go Back   Vista Forums > Vista Forums > Drivers
Vista - Usb, sd, and cd/dvd drive will not read
Old 08-05-2009   #1 (permalink)
Windows Vista Basic
If i put any memory device in, it says i must format the disk before i can use it...but I have alot of information on them and its pointless to delete information that i want to see. If i click on the properties of the disk it says i have 0% unused information. I turned auto play off and even uninstalled ROXIO. With ROXIO deleted, the cd drive now says i must insert a disk but there is already one in there. The other drives still say the same as they did before ROXIO was deleted. This problem started off as the cd drive only messing up sometimes. Then it stopped working completely. Within a few weeks i couldnt use any of the drives. Ive tried many diagnostic tests and no luck.
Old 08-05-2009   #2 (permalink)
Windows 7 Ultimate x64
Re: Usb, sd, and cd/dvd drive will not read
Do you mean DVD drives? And how many arn't working?
Old 08-05-2009   #3 (permalink)
Windows Vista Basic
the optical drive for Cd/dvds. My usb, sd and optical drive will not read the information. It knows something is there tho
Old 08-05-2009   #4 (permalink)
Windows Vista Basic
The drive for CD's/DVD's is brand new
Old 08-05-2009   #5 (permalink)
Vista Home Premium x64 SP1
i had the same problem on my old computer and i downloaded a program...
check out this program
Driver repair: freeware downloads
Old 08-05-2009   #6 (permalink)
No go to this site i think that will help...its freeware..
Driver Detective 2009 - Update your drivers ...
Old 08-05-2009   #7 (permalink)
Windows Vista Basic
Thank you, that software is exactly what I needed, but when i went into my device manager and clicked on each out of date drive (29 of them) it said that Windows has determined that my software is up to date. the major drivers that driver detective said were out of date were the dislpay adapter, all of the IDE ATA/ATAPI controllers, and all but one of my system devices. how do i update them?
Can not write to USB hard drive and disk drive due to "read only" General Discussion
How to: Dual use USB drive ---> Read/Write from Computer and Read from "Stand Alone DVD Player" Vista General
USB drive has become read-only Vista General
READ THIS IF YOU CANNOT GET DRIVE TO READ DISK TO FIX VISTA ERROR! Vista hardware & devices
Re: Cannot Read D Drive Vista hardware & devices
