Go Back   Vista Forums > Vista Forums > Drivers
Vista - DirectX Problem on XP 64bit
Old 2 Weeks Ago   #1 (permalink)
Windows XP 64bit
Hi everyone,
I know that this is a Windows Vista forum, but I really have problems with my XP 64bit SP2 and found out that people familiar with this OS are very few, so I try my luck in this forum.
My system worked perfectly for months after my last directX-update which was 9.0c from March 2009. My Problem is now that I have a few games running through steam, which since a week or something I am not able to start anymore and steam gives me an error message that I need the most recent DirectX installed to run them. (the problem is just the steam check, I think everything would run fine anyways....)
So I tried an update to Version 9.27, which is not working and the installer cancels each time I try, giving me a message that "an internal system error occured" and I should refer to my dxerror.txt-file.
Doing so revealed the following:
[07/13/09 12:58:17] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 189, function: GetDXVersion
Failed API: RegQueryValueEx()
Error: (2) - The system cannot find the file specified.
Current DirectX may be a older version which does not have the version value in the registry.
[07/13/09 12:58:17] module: dxupdate(Mar 31 2006), file: dxupdate.cpp, line: 4666, function: DirectXUpdateGetSetupInformation
GetDXVersion() failed.
[07/13/09 12:58:17] module: dsetup32(Mar 31 2006), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn
DirectXUpdateInstallPlugIn() failed.
[07/13/09 12:58:17] module: dsetup32(Mar 31 2006), file: setup.cpp, line: 1701, function: CSetup::SetupForDirectX
What confuses me now is that I also don't find any problems in my dxdiag screen.
Someone came up with the Idea of doing a system repair using the Windows installation disk since my installed directx seems to be broken somehow, I tried it and found out that there is no such option in the setup of XP 64bit, whyever...
Any Ideas how to fix this?
One more thing please: many people so far started flaming and telling me to get vista, Win7 or remove some of my RAM and use the 32bit XP. I just can't afford gettig a new OS right now so I'm trying to fix this.....
Thanks in advance!
Old 2 Weeks Ago   #2 (permalink)
Windows XP 64bit
Re: DirectX Problem on XP 64bit
Thanks for the answer, unfortunately my Japanese is not that good.
Old 2 Weeks Ago   #3 (permalink)
Vista Home Premium 32bit
I don't know if this will work for you or not.
When I got my Vista Home Premium computer, it had DirectX 10 on it. I couldn't play Everquest, which uses DX 9c. Their system, according to their tech support forums, doesn't support DX10 or higher.
I think you're best solution is to rollback/install an earlier version of DirectX than you have installed now.
Old 2 Weeks Ago   #4 (permalink)
Vista Home Premium 64bit SP2
Try deleting your ClientRegistry.blob steam file , this will force steam to reset (you will have to re enter your login details when you start steam up again , it may help if its simply a steam issue
No virtual environment for 64bit development with DirectX Virtual PC
DirectX Problem General Discussion
DirectX 9.0c problem Drivers
Directx 10 problem Gaming
Directx 10 problem. Vista Games
