Dvd Cd Drive Problem
It wont appear under computer and i have tried 1 dvd and 3 games.
I checked device manager and it shows the dvd drive with a yelllow icon.
It is a liteon ihas324
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
I looked for a driver to download but lite on just gave me a user manual and a picture....
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
Read the tutorial that I gave, you can download from device manager.
It says drivers are up to date.
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
Uninstall it and then try again. The yellow marker means its defective or not installed properly.
Same thing.
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
If it helps any i have heres what ive done.
Device manager uninstall - 3 times
Restarted Computer
And checked that everything was plugged in correctly.
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
Try to roll back from device manager.
Type event viewer in search and look for errors in task manger
Try a system restore from a time the driver was working
Dont know what you want me to do in event viewer and i get a constant 0P3Ia3j4.exe crash.
Dont i have to use the vista cd for a system restore?
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
Also i just fixed the problem of having more than 2sticks of ram in wont that make it not work again?
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
It will not change the amount of ram that you have.
Yes but i fixed a few driver issues that allowed me to use more ram...
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
System restore will only change the Operation System. If you made changes to drivers System Restore will change that.
I dont understand, if you uninstall the driver it cannot say you are up to date when you try to install.
The system restore messed up my system.
And i couldnt boot off the windows vista disc cause the optical drive didnt work so i went to the store and bought a new one.
Fixed my system.
I havnt tried playing a game or dvd with it yet.
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
Im glad that its working, again. Hope that you enjoy the games.
This is commonly caused by:
1.) Installing burning media or, specifically, iTunes.
2.) Removing that software affects your DVD-ROM driver, GEAR Software's driver. You may see it as a "Lower Filter / Upper Filter" value in the registry or something along-side PxHelp20.sys / GEARAspi.WDM, etc.
If you trust Microsoft's "Fix It For Me," here's the link. It does what I'm about to describe.
Your CD or DVD drive can't read or write media
You can go to GEARSoftware.com and locate the driver wizard to install. Save it to desktop. Do not install it.
Or, you can go to regedit.exe and create a full registry backup.
Then, go back into regedit.exe. Go to Edit / Find, then (only check first 3 boxes, NOT the last, which requires a "full match,") and search for:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
....by highlighting only the key between* the brackets. That path should appear at the bottom of the registry editor pane.
Right-click (in the viewing pane to the right) and delete values that suggest:
1.) ClassUpperFilters
2.) UpperFilters
3.) UpperFilters.BAK
4.) ClassLowerFilters
5.) LowerFilters
6.) LowerFilters.BAK
Once done, immediately exit regedit.exe and restart.
You should see your DVD-ROM drive re-appear in MyComputer/Computer.
A third / final solution is to download (from www.yamicsoft.com,)
-WinXP Manager, -Win7 Manager, - Win Vista Manager,
...and locate the Repair Center. It's in the first tab. At the bottom under General Repairs (look over a few tabs to the right once you open the Repair Options, clik the "Fix" dialogue button for "FIX Issue with CD/DVD Drive NOT appearing in MyComputer." Immediately restart.
Good luck,
    Dell
    Intel Core i7 820QM 1.73GHz "Clarksfield" (8 Threads)
    Dell Inc. 0874P6 (U2E1)
    4.0GB Dual-Channel DDR3 @ 661MHz (9-9-9-24)
    ATI Mobility Radeon HD 5400 Series
    (SoundMAX) IDT High Definition Audio
    15"+ Standard Dell Studio 1558 LCD monitor.
    1024 x 768
    (x2) 1TB WD "Elements" External HDD + (x1) 1.5TB WD "Elements) External HDD; 500GB Solid State Storage on laptop.
    N/A Notebook
    N/A
    External (NON-USB!) NZXT CRYO-S (X) Silver. ICE COLD.
    Standard, non-10-key, no fancy backlighting.
    Good 'ol reliable USB 2.0 Microsoft 3-button mouse.
    16 Mbps w/ Aaris DOCSIS 3.0-compliant modem
    Gigabit LAN. Tight network security. (Hopes of getting a Linksys 4-Port Gigabit Security Router with VPN!) Disabled WiFi/Wireless hardware; don't believe in the concept. If I did, would use draft-N adapter.
Turns out it still didnt work with disc so i went back into device manager and checked driver details there was a second driver there that was left behind from stupid itunes...
So i checked up on it sure enough tons of other people were having problems with it messing up there optical drive.
Got this from another forum. (For anyone else that runs into this same problem)
Anyway I have resolve the issue:
To resolve this behavior, follow these steps:
Start Registry Editor (Regedt32.exe).
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Worked for me! :)
EDIT:
Seems the guy up above me already knows.
    Intel Q9550
    6Gb's 1066
    Nvidia GTX 260
    650Gb Black Caviar
    Antec 750
    Logitech G5
    Not fast enough
