Need help with problem signature
dypsis
Good day
My HP Pavailion DV7 Laptop won't shutdown anymore
I have attached a dump file
Thank you
  • Mini030311-01.zip
    HP DV7
I would look at the graphic drivers for now as they are reported as "Holding on to the power"
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp
subsystem.
Arg2: 0000000000000258, Timeout in seconds.
Arg3: fffffa8003cbe040, The thread currently holding on to the Pnp lock.
Arg4: 0000000000000000
This is not conclusive as to which driver though, just a stab in the dark!
What updates have you done recently that caused the issue?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Thank you for the information
I am installing new drivers from Nvidia right now.
I will update with results
    HP DV7
