vista home premium 32bit
Local Time: 04:30 AM
Printer installation problems
I have a home built system with an os upgraded from XP to Vista. I had one printer attached to this system one which worked fine with XP then became buggy once Vista was installed. I just wrote it off since Vista was new it would be eventually fixed as updates became available. I received a new printer "Vista ready" a Lexmark installed the software and it worked once and then would not print again. I recently purchased a wireless Canon Pixma MP495 tried to set it up and get the error as follows:
"Process cannot continue because Print Spooler service has been stopped. Restart the computer to start the Print Spooler service and then try again. <sent image>
I read many forum pages and have tried to correct the problem myself.
Went to command prompt as admin and typed net stop spooler/net start spooler.
ans received: the dependency service does not exist or is marked for deletion
Went to registry and deleted files recommended by forum under HKEY_LOCAL_MACHINE. files under Printer were deleted not the folder itself.
Problem persists.
Long story short I found a thread which matched what is happening to me "exactly". I believe it was listed under "system error 5" spoolsv.exe.
The solution was to replace a corrupt spoolsv.exe file. I sent a pic of my properties file size information box to illustrate my file is larger than it should be.
Is there any way someone could help me download a spoolsv.exe file which may help me correct this problem. Any help would be appreciated.
System Manufacturer/Model Number self built OS vista home premium 32bit CPU amd dual core 2400 Motherboard asus Memory 2gb Graphics Card nvidia Sound Card ?? Monitor(s) Displays hitachi
California
Windows 7 Home Premium 64bit
Local Time: 03:30 AM
Re: Printer installation problems
Try disconnecting the Canon USB Printer and reboot.
Then plug the USB connection in and let it look for the Canon Printer.
Have your disk ready just in case it ask for it.
System Manufacturer/Model Number HP Pavilon Elite OS Windows 7 Home Premium 64bit CPU Intel(R)Core(TM)2 Quad CPU q6600@2.4GHz Motherboard ASUS eK Berkeley Memory 4GB Monitor(s) Displays HP w2408 Vivid Color Widescreen LCD
Keyboard MS WIRELESS Mouse MS WIRELESS Cooling That's where I keep my beer Internet Speed AT&T Uverse DSL
New Zealand
Vista Home Premium 32bit.SP2
Local Time: 10:30 PM
Print spooler is in your services and can be restarted there.
Start search type services, scroll to print spooler highlight it, right click,properties
Set the start up type to automatic in the drop down box and click OK.
System Manufacturer/Model Number Toshiba Satellite Pro A200 OS Vista Home Premium 32bit.SP2 CPU Intel Pentium T2080 code name Yonah Motherboard Capel Valley (napa)CRB PSAF1A-003002 Memory Kingston DDR2-2GB Graphics Card none 945 chipset 256MB Memory Sound Card Realtek Monitor(s) Displays 17 inch Screen Resolution 1280 x 800
Hard Drives 1 x 120GB Hitachi 5400rmp
1 x 650GB Western Digital Elements 5400rpm Internet Speed Fast Telstra Clear 10Mb download speed 2Mb upload speed Other Info Weakest part of my computer is the graphics chipset.
Only ever used a laptop.
Born2golf, thank you for the suggestion however the printer is wireless and is currently not hooked up to the tower. I was attempting to access the printer through the set-up disc/router (which does allow a wireless set up).
System Manufacturer/Model Number Self Built( I will never "buy" a PC) OS Vista Home Premium 32bit CPU AMD Phenom2 XII 560 Motherboard Biostar A780L3L Memory 4GB DDR3-1333 Graphics Card xfx 9800 GT Sound Card Creative X-FI Xtreme Gamer Monitor(s) Displays AOC 22" Widescreen Screen Resolution 1680x1050
Keyboard Logitech Wireless Mouse Logitech Wireless LX310 Cooling 2 front, 2 back,one side Hard Drives 320GB Internet Speed 18/2 cable Other Info Opera/Chrome / EPSON Stylus nx420 / Microsoft Security Essentials / CCleaner / Malwarebytes / OpenDNS / Paint.NET / 7-Zip / Windows Live Mail Client
