35% (plugged in, charging) then not charging. :|
  1. #1
    Newbie
    Philippines
    Local Time: 02:46 PM
    I don't know where to post this...
    So...
    I think theres a problem with my battery
    But I don't wanna risk buying a new one. (cost a lot)
    So I wanna be sure of what's the problem...
    it shows
    35% (plugged in, charging) but it never goes up to 36% at all.
    But after some minutes...
    (plugged in, not charging)
    and my battery charge LED indicator is flashing....
    I did this Method that I seen here
    Battery Charging Is Not Indicated in Vista or Charging LED Does Not Turn On HP Pavilion dv4-1117nr Entertainment Notebook PC - HP Customer Care (United States - English)
    But well, it still didn't go up to 36%
    Some say that I could just take the battery off the laptop...
    and still use my battery charger...
    But I don't wanna risk damaging the charger...
    If that happens, I have two things I need to fix
    And I don't think I can take it.
  2. #2
    Yard Dog's Avatar
    Senior Member
    Central Florida in a small town
    Vista Home Basic. 32 bit SP 2
    Local Time: 02:46 AM
    usa us florida
    Re: 35% (plugged in, charging) then not charging. :|
    Hello and welcome. I read those instructions. and from your post, i can assume that you did those steps correctly and are still having issues. To further trouble shoot this , how bout testing what happens when you are running on battery and the charge is waaaaay low. Plug it in and see if it charges. and if it just charges to the one level of 35% . If this happens after it ( battery ) has been run down to a low power state and only charges to 35% , then to me that would indicate a battery issue. So, with that in mind, let battery run down and then plug it in and report back how far it charges back up to. Also, note how long it takes it to run down to a state where you need to recharge it.
  3. #3
    townsbg's Avatar
    ~~тσωηsвg~~
    US of A
    Mac OS X 10.8
    Local Time: 01:46 AM
    usa
    I concur. Your battery meter may need to be re-calibrated and that is the way to do it. Look in the battery options and see if there is a re-calibration option as there is on my work laptop.
  4. #4
    Newbie
    Philippines
      Thread Starter
    I forgot to tell you...
    when the charger is removed,
    It shutdowns
  5. #5
    Yard Dog's Avatar
    Senior Member
    usa us florida
    k ....
  6. #6
    Yard Dog's Avatar
    Senior Member
    usa us florida
    Quote Originally Posted by Lacie View Post
    It shutdowns
    Thanks for posting this important information.
  7. #7
    townsbg's Avatar
    ~~тσωηsвg~~
    US of A
    Mac OS X 10.8
    usa
    It shutdowns
    As in how it would do if you hit shutdown or does it just turn off?
  8. #8
    Newbie
    Philippines
      Thread Starter
    Quote Originally Posted by townsbg View Post
    It shutdowns
    it just turn off.
  9. #9
    Yard Dog's Avatar
    Senior Member
    usa us florida
    I think what i am seeing here, correct me if i am wrong, is that the only way the computer works is if it is plugged into the wall outlet ? It will not even run off the battery at all, and when it is plugged in, only goes up to 35 % ? Is this correct ? If so, sounds for sure like the battery is shot. Just my thoughts , maybe someone else has some thoughts that may shed more light on this.
  10. #10
    Newbie
    vista home premium 32 bit
    Local Time: 06:46 AM
    Got an HP 530 Laptop with same problem. Original battery had gone and charger was poor, bought both brand new, charger works fine as a mains supplier, but new battery
    wont take a full charge. Emailed battery supplier who sent me a free replacement without question. New battery wont take a full charge. Been on quite a few forums (Vista and HP) and this seems to be a common problem. Spoke to a support person at HP who said it was a Vista problem but I cant see any solutions on the Microsoft website. Ive been advised to reinstall XP (Which I prefer) as it is a Vista problem so will try that when I get chance. I`m just sick and tired of being passed from MSoft to HP and back again. I feel a Mac coming on soon!!! Someone please help, thanks
Page 1 of 3 123 LastLast
35% (plugged in, charging) then not charging. :| problems?
Plugged IN Not Charging daredevil95 General Discussion 15 01 Dec 2012
battery plugged in, not charging jennifer b Vista hardware & devices 6 15 May 2010
Plugged In, Not Charging Battery Ted Vista hardware & devices 19 10 Aug 2009
Solved PLEASE HELP! Plugged in, not charging? ComputerAge General Discussion 13 04 Apr 2009
98% Plugged in, not charging. Rathman General Discussion 5 05 Nov 2008
