PCI / USB driver problem
  1. #1
    Junior Member
    Vista Home Premium 64bit
    Local Time: 10:59 PM
    Everytime I restart my computer I get a bunch of "found new hardware" and its all my pci/usb devices. If i click "ask me later" it works fine and I can use the front usb ports on my CM Storm case. If i click "dont ask me again" they stop working completely. Note under Device Manager all these devices claim to be "This device is working properly"
    Except I have 1 unknown device that says it hasent installed a driver yet and when I try to install it I get.
    NVIDIA nForce PCI System Management
    An error occurred during the installation of the device:
    The driver installation file for this device is missing a necessary entry. This may be because the INF was written for Windows 95 or later. Contact your hardware vendor.
    Lately my computer has been choking itself so ive been fixing anything I can find to help. Any support will be appreciated.
  2. #2
    Yard Dog's Avatar
    Senior Member
    Central Florida in a small town
    Vista Home Basic. 32 bit SP 2
    Local Time: 11:59 PM
    usa us florida
    Re: PCI / USB driver problem
    Hello, have you installed all applicable Microsoft Updates ?
  3. #3
    Junior Member
      Thread Starter
    Ive been installing any microsoft updates that appear with "Windows Update" on my computer. I went to Microsoft's site for help but their autofix program ended up giving me the same error after it found the driver aswell.
  4. #4
    Yard Dog's Avatar
    Senior Member
    usa us florida
    Have you made it up to SP2 yet ? I ask because you specs do not indicate Vista Home Prem 64 bit SP 2 . Just checking .
  5. #5
    Junior Member
      Thread Starter
    Im not entirely sure, what is the fastest way to check this?
    EDIT** Yes i have sp2 installed.
  6. #6
    Yard Dog's Avatar
    Senior Member
    usa us florida
    Go to Start, Control Panel, System, open that up and see what it shows you as your OS .
  7. #7
    Junior Member
      Thread Starter
    Yes sp2 is installed, in my profile I listed all my specs for anything else.
  8. #8
    Yard Dog's Avatar
    Senior Member
    usa us florida
    K.. good .. In Device Manager , from your Start button , Control panel. Any yellow icons ?
  9. #9
    Yard Dog's Avatar
    Senior Member
    usa us florida
    WHen you open up the Tree ( plus sign ) and attempt update, does it still show latest driver is installed ?
  10. #10
    Junior Member
      Thread Starter
    Only yellow icon is the one I listed in the first post, the "unknown device" that I can find the driver for but wont let me download the driver.
    The drivers for this device are not installed. (Code 28)
    The installation failed because a function driver was not specified for this device instance.
    To reinstall the drivers for this device, click Reinstall Driver.
Page 1 of 2 12 LastLast
PCI / USB driver problem problems?
Driver problem jen004 Drivers 7 01 Jul 2009
I have problem starting up Vista - problem with driver Tomassuver Drivers 1 15 May 2009
for user that have the driver problem driver. How do we clean inst GT Vista installation & setup 1 22 Mar 2008
RE: Vista install problem - Failed to add driver package into driver s Darrell Gorter[MSFT] Vista installation & setup 1 27 Mar 2007
WLMd crashing problem, possible problem with Vid. Driver?? James Welch Vista General 0 02 Dec 2006
