| 32 bit | Can't Print Problem When I try to print a menu comes up asking if I want to save the file???? No, I want to print it. Why can't I print??? I am not liking this Vista at all. |
| Vista Ultimate x64 SP2 | Re: Can't Print Problem Sounds like you don't have a printer installed and Vista is trying to save your bacon, plus your document as a MS XPS document. Go to printers or network and install your printer, by clicking on Add a printer from the task bar above the white area of the window. Just follow the instructions there and your printer should install as the default printer and you should be in business. |
| Print Problem | Live Mail | |||
| I can't print - spooler problem | Vista print fax & scan | |||
| Print Wizard Problem | Vista General | |||
| print driver successfully installed but still a problem with print | Vista print fax & scan | |||
| Re: IE7 Print Problem | Vista print fax & scan | |||
