Go Back   Vista Forums > Vista Forums > General Discussion
Vista - Normally slow or a problem?
Old 03-08-2008   #1 (permalink)
Vista Ultimate x64
Hello all. I am new to Vista x64 as I am a WinXp kinda guy but thought I would give it a try to see what all the hoopla was about. First, I want to thank the authors of the tutorials section - WONDERFUL... Now, my question is this, when I go to START then ALL PROGRAMS then click on a program folder (any one will do) there seems to be a large lag time before the folder opens up. I am talking about 5 seconds or so. IS this normal or is there an adjustment to speed this process up. THANKS for any responses given..
Old 03-08-2008   #2 (permalink)
Vista
Re: Normally slow or a problem?
Did you try increasing the menu speed?
In the Registry, go to HKey/Current_User/Control Panel and select 'Desktop'.
In the right pane, look for 'MenuShowDelay', and right-click to select 'Modify'. Change to 0 for no delay. (I think the default is 400)
Solved Slow startup problem General Discussion
Slow Boot Problem Vista performance & maintenance
Windows Live Mail hogging CPU – renders itself and XP into slow, slow, slow mode . . . Live Mail
Internet is very slow problem Network & Sharing
Vista Really slow, what could be a problem ! Vista performance & maintenance
