br> br> |
| | Thread Tools | Display Modes |
| Stay down...fool ![]() ![]() Rep Power: 10 ![]() ![]() ![]() | Narrowing down my s3 problem but need help. I'm still trying to figure out why my dvd drives won't recognize any media after s3 sleep but work fine after a reboot.( it's getting old rebooting everytime i want to watch a movie. )In device manager i see the drives, they show up in my comp and bios too..They don't disappear like some problems i've read about...just won't recognize any dvd i put in it until restart. One thing i notice is that in device manager the power data for the drives show: Power state mappings: S0 -> D0 S1 -> Unspecified S2 -> Unspecified S3 -> Unspecified Is that normal? If not how can i "specify" s3 sleep in the drives? All drives are Vista certified and have the latest firmware. I would really appreciate help with this problem. I'm also thinking maybe the Gear software i use with Itunes may be causing this so i'm googling that too. |
| Administrator ![]() Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: Narrowing down my s3 problem but need help. Hi Cwatson, In your Power Options in the Control Panel, check to see if using the Sleep option with the setting of Multimedia settings When sharing media to Allow the computer to enter Away Mode instead will help. (Step Two if needed) Power Options and Sleep Mode Problems Hope this helps, Shawn |
| Stay down...fool ![]() ![]() Rep Power: 10 ![]() ![]() ![]() | Re: Narrowing down my s3 problem but need help. Thanks Shawn for the help. I have just set my Multimedia settings to Allow the computer to enter Away Mode. After work i'll be able to test it again and i really appreciate your giving me step 2. Be back later with results. |
| Stay down...fool ![]() ![]() Rep Power: 10 ![]() ![]() ![]() | Re: Narrowing down my s3 problem but need help. That didn't work. Allow the computer to enter Away Mode made my monitor shut off at specified time but the pc wouldn't sleep not even manually. Since my psu is about as loud as a Xbox 360 and my case has two huge blue fans on the side i like to have it all shut down at night, i also tried prevent idling to sleep and after making it all manually sleep the next morning the pc came back on but my monitor wouldn't until a reboot. I'll try step 2..thanks again for the help. I know i'll figure this out eventually. |
| Administrator ![]() Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Re: Narrowing down my s3 problem but need help. Cwatson, You might check the other options here to see what may be preventing your computer from going to sleep. Sorry about the wrong link above. ![]() Power Options and Sleep Mode Problems Shawn |
| Display Modes | |
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Jim Hansen | Vista General | 3 | 12-16-2007 08:09 PM |
| Generic McAfee Problem Message in Vista Problem Reports | cyberbuff53 | Vista performance & maintenance | 0 | 12-01-2007 07:55 AM |
| fixed unable to delete email problem, now I have new problem | j2 | Vista mail | 19 | 03-29-2007 08:25 PM |
| audio problem with my sony vaio laptop and x64 problem | =?Utf-8?B?YWxleA==?= | Vista hardware & devices | 1 | 07-14-2006 09:32 AM |
| Vista Upgrade Problem - Windows Explorer Loop problem | Steve S | Vista installation & setup | 0 | 06-27-2006 10:15 AM |
