Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > General Discussion
problem with shortcut
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 04-20-2008   #1 (permalink)
Newbie
Vista Home Premium 32bit
toyboxmonster is on a distinguished road
  toyboxmonster is offline
hi... i have a slight problem that i'd like to find help for. there is this shortcut i have on my computer that won't delete bacuase the file is no longer present ( i deleted it a long time ago). what can i do to delete the shortcut?
(it says "could not find this item... this is no longer located in C:UsersVistaAppDataRoamingMicrosoftWindowsRecent")
Old 04-21-2008   #2 (permalink)
Senior Member
Home premium 32 bit
Canada
t-4-2 has a spectacular aura aboutt-4-2 has a spectacular aura aboutt-4-2 has a spectacular aura about
  t-4-2 is offline
Re: problem with shortcut
Quote:
toyboxmonster
View Post
Hello toyboxmonster,
For your future reference only. when you create a shortcut, the file/program from which the shortsut launches is the "source". Meaning, in layman terms, when a shortcut is activated, the system goes find the source. If you moved it or worst removed it, the system will go crazy trying to find it. That applies to deleting the shortcut. The system cannot find the source, thus can't execute delete command.
The only thing I can suggest, AND DON'T HOLD ME TO THAT, is to re-install that file, delete the shortcut, then the file again. Meanwhile I'll go search for a concrete solution. If I find one, I'll come back to tell you.
Old 04-21-2008   #3 (permalink)
Senior Member
Home premium 32 bit
Canada
  t-4-2 is offline
Quote:
t-4-2
View Post
Quote:
toyboxmonster
View Post
Not sure if this will help. It's called " Take Ownership of An Item ". After you have that installed, right at the shortcut, click Take Ownership, then proceed to delete. Let me know if this help. Link below : --
Context Menu - Take Ownership
Old 04-22-2008   #4 (permalink)
garysgold's Avatar
Geek
vista home premium 32 bit
Maine, USA
garysgold is a name known to allgarysgold is a name known to allgarysgold is a name known to allgarysgold is a name known to allgarysgold is a name known to allgarysgold is a name known to all
  garysgold is offline
Welcome!
I would try the take ownership idea first. If that doesn't work, I would try a quick reboot. Press Ctrl+Shift+Esc. (Task Manager). On the processes tab, highlight 'explorer.exe' then hit the end process button on the bottom left. Everything on your desktop will vanish (don't panic). Next go the the Applications tab, click the New task button. Type in "explorer.exe" (no quotes) and click OK. Your desktop will return, hopefully without the troublesome shortcut.
Hope it works,
Gary
Display Modes
Solved Shortcut image problem BigEasy18 General Discussion 3 07-31-2008 11:05 AM
Whoops.. shortcut problem! colt22 Vista General 1 02-28-2008 10:26 PM
HELP!!! Shortcut problem..! colt22 General Discussion 1 02-28-2008 09:54 PM
Shortcut problem kdenhart Vista General 2 01-02-2008 01:54 PM
Send Shortcut Problem debcsus Vista mail 0 10-29-2007 08:01 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
