this might sound stupid, but help please..
frantaolej
I bought a new laptop with vista home premium 32, she set it up as a standard user an now it's impossible to install anything onto computer because the system is still asking for admin. password and even if we know that one (well there haven't been password set up) in that dialog box it's nowhere to write it. How we can make her account changed to administrator??
Only one way I came up with is to use recovery disk set it up differently, well not sure about that and don't fancy it much. Is there an easier way?
thanx
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
thanx
Hello frantaolej,
Start your machine in Safe Mode, use the link at the end of this post to install the "built-in administrator". After that, reboot to normal mode, logon to the new built-in admin account, change her standard account to admin account. This time make sure her account has a password. Keep the built-in admin. It'll come in handy--- real handy.
thanx
Hello frantaolej,
can't see the link mate sorry
Hello frantaolej,
Hello frantaolej,
Darn if I know what happened to the link ! Here is another one.
http://www.vistax64.com/tutorials/67567-administrator-account.html
Turn on the Computer
Tap F8 Untill you see Advance Boot Options
Choose First Option Repair Your Computer
You will See a Screen which says Install Now. Towards Left Bottom you will see Repair Your Computer Link
Click on Repair Your Computer
Click on Command Prompt
when you see the Comand Prompt
Go to c:\Windows\System32
Type in " ren magnify.exe man.exe
Type in ren " cmd.exe magnify.exe "
exit and restart the Computer
When prompting Password for your Current User Account and the Botton left you can see Easy of Access Options
Click on Easy of Access
Then Check the Box for Magnifier and click on OK
you will get the Command Prompt
In the Command Prompt Enter net user net user administrator /active:yes
Restart the Computer
Click on Administrator Account
Go to Control Panel and Change the Standard Account to Administrator
restart the Computer Log in to your User Account!
Now you have Administrator rights :)
As its not good to have the default Administrato Account turned on
In the Command Prompt Enter net user net user administrator /active:no
And rename magnify.exe to cmd.exe in c:\windows\system32
And rename man.exe to magnify.exe in c:\windows\system32
Enjoy!
LOL that's a cool trick, going through the ease of access panel.
    Intel Core2Quad Q9450
    nForce 790i Ultra SLI(evga)
    8 GB DDR3 1333MHz
    2 e-GeForce 9800GX2(SLI mode)
    WD1500AHFD
    (Raptor 150 GB 10,000 RPM)
