| Vista Business N x64 | Keyboard problem: US International setting. Hi there and thanks for reading ![]() Lately, whenever I'm using MSN, something happens to my US International keyboard setting. My keyboard setting is usually at NL - United states International. Whenever I type a " followed by an e for example, it writes: ë The problem: Now my best guess is that it's something MSN does, but after chatting for a bit, My keyboard setting sometimes messes up. Instead of typing "it's" for example, it types: ""it''s""' It really messes up. "e results in ""e I have tried setting the keyboard to a different setting and back, but it doesn't work. If I switch to US -United states International for example, it works again, but switching back to NL messes is up again. so far, the only solution I have found to get NL - united states international to work again is reboot my computer ![]() Has anyone ever seen this? It is not something specific to my computer. My Vista 32bit at work has the same issue.... SOMETIMES... Kind regards, Wracky |
| Ultimate SP1 x64 & x86 | Re: Keyboard problem: US International setting. try clicking on the icon : 'A|B' on the bar above where you type, and make sure the 'Script' is set to 'Western' |
| Vista Business N x64 | Re: Keyboard problem: US International setting. Thanks for your quick reply ![]() The script in MSN is set to western. Also: MSN usually works, but sometimes, the keyboard setting gets messed up. When it is, it's messed up system wide, not just in MSN. I experience the same problem right now while typing this notepad too. |
| Ultimate SP1 x64 & x86 | Re: Keyboard problem: US International setting. Same problem with command prompt? Did you change the keyboard to check it? Language has been changed in control panel / keyboard language? Check if you have an irq conflict with the keyboard. Sorry that's all i can think of for the moment. |
| Vista Business N x64 | Re: Keyboard problem: US International setting. Thanks again ![]() The Keyboard is on IRQ 1?(according to the device manager) and does not cause any conflicts. There is only one language in the keyboard language menu, and that's NL - United states international. My keyboard is fine, since it works on US - United states international, just no longer on NL. A reboot always fixes the problem. I also have this at work some times, with a different system. |
| | #6 (permalink) |
| Vista Ultimate x64 | Re: Keyboard problem: US International setting. I solved this problem by changing my input language to English (Zimbabwe) and then selecting United States international there. Now it works fine, I can make ümlauts and so forth. Just an FYI. Also its a pain to register given that all I wanted to do was post a quick answer to help people, I gain nothing from it. Maybe some kind of system where anonymous people could make one post, which would then be approved by an administrator, could fix the problem. |
| Keyboard and international accents | Vista mail | |||
| Keyboard setting | Vista General | |||
| PROBLEM WITH VIDEO SCREENSAVER (INTERNATIONAL) | Vista General | |||
| Video Screensaver International PROBLEM! | Vista General | |||
| Setting up keyboard? | Vista General | |||
