br>
Thread Tools | Display Modes |
#1 | ||
Pass Me a Beer
![]() ![]() ![]() ![]() Join Date: Jan 2008
Vista Ultimate x64
Hello Again Vista64... OK, so I've been building a new system over the last few weeks.. I'm almost done, and probably in the next day or 2 I'm going to be throwing Vista 64 on my new Build.. so before I get into that OS install mess I figured I'd ask the Pro's (Vistax64) what they thought and what all I should be looking for, worried about.. etc...
I've got myself a Q6700 with GO eVGA 750i FTW Mobo ![]() 4GB RAM.. Coming, only have 2 for now.. (I heard while doing 64 install only have 1 stick of ram in.. after it's done add the other.. why?? will that make things easier) Seagate Cuda 7200.11 500GB 32mb Cache Corsair PSU Cooler Master 690 case, modded.. The rest you don't really need to kno. Basically I'm getting ready to install 64 bit on my new build. and I was hoping for some Direction.. some input on what problems I can expect to have.. I've read that a lot of people are doing fine with games and drivers.. so I don't think I'll have a problem there.. I play some CS, some Crysis and a lil COD4.. I wont have any problems with all those right. So if anyone has any suggestions as to what I should do, things that I should LOOK for during install.. any tips to help with smooth install and smooth using.. please share.. What are the basic and often seen problems that I may have.. Should I have my CPU and Mobo drivers ready for after OS install.. or can i just update them online after install is finished.. Please share ur info with me I'd appreciate it.. Thanks in Advanced everyone. /Cory |
#2 | ||
Grumpy
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Vista x64 Ultimate SP1
Looking at your spec, you should have no problems.
From my experience the main problem with Vista x64 is noob's blaming there old hardware incompatibilities or their lack of knowledge on the OS. Edit Just one thing I would recommend is installing SP1 as soon as you have the OS loaded ![]() |
#3 | ||
Junior Member
![]() Join Date: Apr 2008
Dual Boot Windows XP Professional SP3 and Windows Vista Ultimate x64 SP1
solo; 550w neohe; ga-k8n51pvmt-9-rh; x2 4400+; mine; 4gb pc3200c2; raptor 74gb; hd501lj 500gb; 8600gts; imon; px-716a; sata-bay; floppy/cardreader; x-fi xtreme gamer; dual tv-card; 120mm rear-fan; 2*92mm front-fans; 140mm mobo-fan; 100mm cpu-fan; 70mm vga-fan; bigng; 2*50watt amp; cf-card rescue system
#4 | ||
Pass Me a Beer
Vista Ultimate x64
Hm... cool sounds like I'll be having no problems then.. or hopefully not. We will see. I'm going to try and do it tomorro.. or hopefully tomorro.. so tell me this.. what about a Pirated version of 64... some guy gave me a disk.. but I'm not to comfortable with that idea.. and with having to WATCH witch updates you let go. and all that crap.. ya, I'm not to sure about that. do cracked versions work just as good as the regular ones..? or should I not risk that???
and ya I'll use both sticks of RAM and i'm sure the install will go fine.. |
#5 | ||
Vista enthusiast
![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
pirated version of Vista?? "some guy" gave you a disk? cough cough...lol
Yeah, I wouldn't install that, not a good idea...more problems than you could imagine. Nice system setup though ![]() |
Core 2 Quad Q9450 OC'd 3.2GHz
EVGA 780i A1 3-WAY SLi OCZ 8GB NVIDIA SLi ThermalTake ToughPower 1200watts 0133RU ThermalTake MAxOrb CPU Cooler 3XBFG GeForce 9800GTX OCX TRI SLi 4X500GB 7200.11 Seagate HD's Pioneer 7.1(8speakers+12"sub)/46"HDTV 1080P LG GGW-H20L super-multi BluRay burner "If it isn't broken, don't try to fix it." |
#6 | ||
Pass Me a Beer
Vista Ultimate x64
ya, some guy work works in the IT department at a family members work.. he gave it to me.. said I'd have no problems.. and all would be fine... not some Cough Cough.. lol OK..
How can it have that many problems.. it's the same thing all you guys have.. except without a real Code.. or is there more to it than that.. I'm not saying I'll use it. I'm not sure. I wanna get going soon tho on this.. Your a vista Enthusiast, of course you say buy it.. he he. Got a Spare copy I can use.. or even better.. is there a 30 day trial Of Vista 64 Ultimate I can download or anything from MIcrosoft.. and use it on my new build.. and then within the 30 days I will have time to Buy it.. sicnce I cant right now.. all my cash went into the good parts.. Is that possible, download and put on a CD a trial of Vista 64bit?? |
#7 | ||
Newbie
![]() Join Date: May 2008
vista x64 Home Premium sp1.
Buy an OEM version of Amazon its a lot cheaper, i saved £200 and it installed without any problem. The only thing the oem lacks is ms support and you can only copy to 1 pc motherboard. I only need it for my gaming rig so its fine for me.
Here is my setup. Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz (2 CPUs), ~2.4GHz 4 Gigs DDR2-SDRAM PC2-5300 NVIDIA GeForce 7900 GS x2 Dual (upgrading) AGEIA PhysX 100 Series PCI Card Creative SB Audigy 2 ZS (X-FI removed after vista install) NVIDIA RAID Stripe 500 Gig (Dual HDD config) Creative Inspire T7900 7:1 Speaker system. Logitech G15 (Blue) Gamers keyboard. Logitech MX518 Gamers Mouse. Saitek Cyborg Evo. Vista Home Premium SP1 x64 |
#8 | ||
![]() ![]() ![]() Join Date: Feb 2008
Vista Ultimate SP1 x64
Just do what i did, d/l or borrow the 64 bit version then use it for 30 days until the tryout period expires b4 u buy. It helped me iron out any bugs & i didnt have to worry about not being able to send the oem version back to the retailer (which you cant do). Also, i decided to buy the retail version from ebay, since i only wanted the 64 version of ultimate, i got it for around £90, considering the oem version is around £110 & the standard retail is £300 i saved a small fortune.
Also, save sp1 to your usb pen so the first time you log on to your newly created vista user account you can install it. |
#10 | ||
Newbie
Vista Home Premium 64
I think your Vista 64 program will be OK on your rig, (mine Asus P5K Premium WiFi-AP, Q6600 O/C 3GHz, 8GB Reaper RAM, Samsung SATA 500GB, Ati X1950 Pro). The main problem with Vista 64-bit is not the O/S itself but the other software.
Vista Compatable is just that, 32-bit 90% OK, Vista 64-bit more like 50%! Corel Paint Shop Pro Photo X2 says on the box 'System Requirements Microsoft Windows Vista'. But it did not work general opinion is vista compatable is 32-bit compatability. As a friend who knows a lot and worked for some of the 1970's builders and program writers says:- " Do you remember before Vista was released all the computer manufacturers were selling new systems with labels on saying they were Vista ready and when Vista arrived they could not run the program properly with not enough memory and poor graphics. The courts decided that Vista ready meant that they could be made to run Vista, but then so could just about every other computer. There was a similar ruling on Vista compatible, you might have to run the thing as a 286 but it would run. It would take twenty years at least to write a new operating system, what they do is modify what has gone before, if they deviate and make it incompatible they get flak. If they make a change that some customers have asked for they get others saying it is not what they want. Vista compatible is a trade mark phrase that only applies to Vista 32 and in fact it only means, and the courts agreed, that the program will not crash, many of the computers and programs will not actually run properly but it seems the phrase does not mean that. Most low level utilitys that are designed for 32 will screw up a 64 bit system big time. That makes you think? It mirrors what I have found. I used the Beta 2, RC1 and RC2 in 64-bit and its as bad now for finding drivers as it was then. In fact Linsky its worse as they no longer have Vista 64 support for thier Wireless Modems! You have to look at it logicaly if you were a software producer would you want users to carry on using the XP software they bought from you 6 years ago; or make some new software that works with Vista 64-bit so they will buy some new stuff and you make more money? The general feeling in UK is if they could get away with selling software that stops working every 2 years and you had to buy it again they would. I been looking for a 64 bit photo editing programme for the last 6 months and still looking! Jannerhank |
