Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > General Discussion
32 bit premium TO 64bit Premium help!!!
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 06-01-2008   #1 (permalink)
Newbie
Vista Home Premium 32bit
Maca0716 is on a distinguished road
  Maca0716 is offline
Hello my first post and i apologise if this is a simple question with a simple answer but i am very confused.
Just got my new PC which has 4 gig of ram in but premium 32bit now as i understand that 4 gig would be wasted if i didn't have 64bit installed.
My computer meets the requirements but here is my question.
What do i actually have to BUY? it seems so confusing do i buy Vista Ultimate which would cost me £200 or is there something else i can buy which would be cheaper?
I have looked around and the only thing i can find is these dabs.com - Microsoft Windows Vista Home Prem SP1 64-bit OEM (66I-01939)
And it sounds very confusing when it says it is used by system builders obviously i am not a system builder and i want an easy installation process.
Please someone shine some light and give me an answer to probably a simple question.
Also if you could link what i would have to buy and would it be a case of just putting in the CD and off i go?
Many many thanks in advance.
Old 06-01-2008   #2 (permalink)
xguntherc's Avatar
I Click Home To Much
Vista Ultimate x64
Vegas Baby
xguntherc is a splendid one to beholdxguntherc is a splendid one to beholdxguntherc is a splendid one to beholdxguntherc is a splendid one to beholdxguntherc is a splendid one to beholdxguntherc is a splendid one to beholdxguntherc is a splendid one to behold
  xguntherc is offline
Re: 32 bit premium TO 64bit Premium help!!!
Well, ya you need 64bit to utilize all 4GB of ram..
as for OEM, and system builder. it does not mean it's for a builder and that it's not a full or easy copy.. it means that it's just a single, one time use, no upgrades, and no Microsoft support.. for people like me that built his own machine. and would not use microsoft even if I had a problem..
So, you can either go with a new OEM disk.. or you can always use this..
Windows Vista Alternate Media
you only pay the shipping, so like $10-$15 and they send you a upgrade from your current 32bit.. to a 64bit.. check out the link. they send you a new disk in the mail with 64bit..
Good Luck!
Old 06-01-2008   #3 (permalink)
Newbie
  Maca0716 is offline
Quote:
xguntherc
View Post
Good Luck!
Thanks very much.
Display Modes
Can't install Vista Premium 64bit newbies13 General Discussion 18 08-03-2008 01:03 PM
installing home premium 64bit w/ 4g RAM phats_O Vista installation & setup 4 02-19-2008 06:05 PM
Can't install 64bit Home Premium n5667 Vista installation & setup 5 12-14-2007 03:47 PM
64bit home premium orestes General Discussion 2 10-24-2007 11:21 PM
XP Pro 32-bit to Vista Home Premium 64Bit kryptik Vista installation & setup 2 06-30-2007 02:12 PM
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
