Go Back   Vista Forums > Vista Forums > General Discussion
Vista - installation problem
Old 07-17-2008   #1 (permalink)
Vista Ultimate x64
I try to install windows vista ultimate on my HP KW303EA but i have problem...
i boot up from the cd , it loads the windows install files... after that i see the blue bar running for about 6 seconds and i see
the windows vista install background... i noticed that my hard drive activity led is always on(red) but the install will not go
on.. it is just stuck at the start i can even get to the windows with the product key...
Please help...
Old 07-17-2008   #2 (permalink)
Vista x64 Ultimate
Re: installation problem
Are you doing a clean install? Do you have the latest BIOS rev on the laptop?
Old 07-18-2008   #3 (permalink)
Vista home premium 64 bit
How much memory are you using.
Is it on a ide/sata drive or a raid array?
I am at my end with the installation problem Vista installation & setup
Installation problem General Discussion
Problem in installation! General Discussion
Installation Problem Vista installation & setup
Installation problem Vista installation & setup
