Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Go Back   Vista Forums > Vista Forums > General Discussion
Permission problems?
LinkBack Thread Tools Display Modes
Old 07-27-2008   #1 (permalink)
Newbie
vista 32 Vista Home Premium 32bit.
I was able to make an Administrator Account but even when i am in it it tells me I don't have permision! I cant run programs I can't download anything online I can't use my voip telephone anymore I cant make temp files it says you need permision for that i hit ok and it just comes back Do I have a virus? help
Old 07-27-2008   #2 (permalink)
johngalt's Avatar
Antidisestablishmentarian
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: Permission problems?
Hi, conner2u, and welcome to the forums.
If you cannot do any of those things then something is wrong with your computer. Without more information all I can suggest for *truly* fixing it in a one stop is to format and reinstall Vista from scratch - because , after every install I ***CAN*** run programs download anything online use my voip telephone anymore make temp files
I highly suggest that you give us more detailed explanations of what is going on and what you have tried to do to fix it.
Old 07-27-2008   #3 (permalink)
Newbie
If I reinstall vista won't I erase all my data? I already tried restore and it didnt help
Old 07-28-2008   #4 (permalink)
Spd2Last's Avatar
Pre-Engineer
Vista Home Premium x64 SP2
If you reformat your computer, then yes you will lose everything that is currently on the hard drive. Like john said, we need a more detailed explanation of what is going on, what programs you are trying to run, and what you have done to it. What did you mean by you being able to make an administrator account on the computer? By default, the main user is the administrator of the computer. More details of everything please...
Old 07-28-2008   #5 (permalink)
sidney1st's Avatar
Ultimate SP1 x64 & x86
Quote:
conner2u
View Post
Best thing to do is to check.
Download this program: http://download.hijackthis.eu/HJTInstall.exe
Install it and run it.
A log file will be generated, attach it here.
Display Modes
UAC-Permission problems bobg Vista General 3 02-12-2008 04:54 PM
You need permission John Vista security 1 10-05-2007 09:52 AM
Strange permission problems when accessing SBS 2003 network share Martin Ennemoser Vista networking & sharing 2 06-22-2007 04:41 PM
Can't rename a file due to permission problems Roof Fiddler Vista security 0 09-26-2006 05:59 PM
No permission to run IE 7+ Gene Girard Vista account administration 2 06-15-2006 11:48 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
