safe mode boot problems!!! please help
ahouse86
Hello,
I let my brother borrow my computer and he gave it back with some malware that caused it to run very slow. Best-buy did the scan and found that some of the system32 files got screwed up. I cannot boot into safe mode by pressing F8 and its driving me crazy. I had the files backup and reformatted the HDD instead of paying the $130 for best buy. Even after the reformat i still cannot boot into safe mode. Nothing is found by my kaspersky, webroot, or adaware software. I can boot into safe mode by turning the power key off. I also did the sfc but it said "98% verified with corrupt files found" but when i went to the log it said that all the files were verified and no files were repaired. I'm really just worried that the problem is still there even after using the recovery disk. I'm not really sure where to go from this point.
My computer is a Toshiba Qosmio with vista ultimate
Thanks,
Hi Andy, and welcome to Vista Forums.
I'm a bit confused. You say "Even after the reformat i still cannot boot into safe mode." , but also say "I can boot into safe mode by turning the power key off.". I'm not sure what you mean by this since the statements conflict with each other. Could you please explain this a little more.
Since you have backups, you might try doing another clean reinstall of Vista to see if it was just something that went wrong during installation last time.
Do you also have a recovery partition instead of just the recovery DVD? If so, you might try reinstalling Vista from the recovery partition instead.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
If your Windows System files got messed up, you need to reinstall Vista (90% sure). If your willing to pay to get rid of the malware, you may want to look into McAfee's virus removal service. They control your computer remotely and you get to watch them kill off all the malware from your seat (Fun as heck to wave bye to the viruses :)) You also may consider wanting to buy McAfee, its one of the best antiviruses out there.
Computer infected? Let McAfee remove that for you.
    Dell XPS 420
    Dual Intel Core 2 Duo E6850 @ 3.0 GHz
    ACPI x86
    nVidia GeForce 8800 GT
    IDT High Definition Audio
    SyncMaster 2493HM Digital 24" Widescreen
    1920 x 1200
    Dual Western Digital 500GB Disk Drives
    Logitech G11 Gaming Keyboard
    Logitech G5 Gaming Mouse
    6k KB/s DL, 700 KB/s UP
Is you keyboard USB?
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    Drive
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Surface Ergonomic.
    Logitech Performance MX
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
I fail to see what that has to do with his virus?
    Dell XPS 420
    ACPI x86
    1920 x 1200
How do you know his problem is caused by a Virus? not being able to get safemode from F8 could be a USB keyboard without legacy mode enabled in the bios.
    Ryzen 9 5950X
    Creative
    Drive
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    WinTV NovaTD
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
I cannot boot into safe mode by pressing F8... I had the files backup and reformatted the HDD... Even after the reformat i still cannot boot into safe mode. Nothing is found by my kaspersky, webroot, or adaware software. I can boot into safe mode by turning the power key off. I also did the sfc but it said "98% verified with corrupt files found" but when i went to the log it said that all the files were verified and no files were repaired.
well, are you sure you formatted the partition properly? if you just installed windows again without formatting the partition, the previous windows installation gets saved in folders like windows.old
by pressing F8 you do get the "windows advanced options" right?
what power key are you referring to?
you might want to try a checkdisk to look for HDD malfunctions.
did you try a different keyboard, as you were suggested?
when I power on the computer and press F8 all that happens is that I get an blinking "_" then windows starts up normally. I've reformatted a couple of times to try and figure this out but I'm afraid that if I choose the option from the toshiba recovery disk "erase all partions and data from the hard drice. this make take a couple of hours," that the recovery disks are going to be no good. Also I dont have a USB keyboard.
I forgot, I can go into safe mode if I hold down the power key to turn off the computer incorrectly then boot it up. I then get "safe mode", "with networking or cmd prompt"
Okay, so you can get into Safe Mode with networking. From there I still recommend McAfee or AVG Free
    Dell XPS 420
    ACPI x86
    1920 x 1200
ahouse86 are you using a laptop? I am asking this because you mentioned a recovery disk. If you are not using a laptop please do not format the drive again you are just waisting time. If you have formatted the drive and reinstalled the OS there will be no malware on the system (I know microsoft are bad but not that bad).
If you are using a laptop then just reinstall from the backup as will be discribed in the manual.
Hope this helps the ambigous question.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Logik
    Technika TKOPTM2
    Creative Inspire 7.1 T7900 Speakers
    Trust Graphics Tablet
To everyone posting: A little bit of reading and a simple Google search would have prevented *half* of these questions.
Toshiba Qosmio Laptop Computers
Yes - it is a laptop. No, it is not a USB KB. Yes - it will have a recovery partition.
ahouse86 - I just wanted to verify - you have used Safe Mode on *this* laptop before, and know *when* to press the F8 key, correct? The reason I ask is that if you press it too early (which is before that blinking underscore cursor) the Windows system is not going to recognize that you are trying to get to your advanced options.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech G15 (gen 2)
    Logitech MX Master (shared)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
I've been into the safe mode by pressing F8 before. I'm really just not sure as to why i cant get into it now, and how to fix the files that the scd found that were incorrect
If I do delete all of the partions from the laptop computer wont that also delete the recovery partions and render those disks useless. If thats not the case will that correct the problem that I'm having
