| | #11 (permalink) |
| Vista Bussiness x64 PL | Re: Power Options Corrupt (power plan unavailable) |
| | #12 (permalink) |
| Windows 7 RC x64 | Re: Power Options Corrupt (power plan unavailable) Thank You !!!!! |
| | #13 (permalink) |
| Vista Ultimate | Re: Power Options Corrupt (power plan unavailable) so i have tried to follow Flavius directions in post 8 however i am stomped by the last part of your direction..... the part where u say: Next choose File>>Import :choose my *.reg file,apply +restart computer When I click import on the registry editior i am confused as to what i should type as the file name.... Can u please be a bit more specific... also wat am I doing with the Power opt attachment.. when i open it where do i save it to?? The last part of the directions has me COMPLETELY stomped so hoping for a clearer response.. Thanks and much appreciation all the way from trinidad and tobago! |
| | #14 (permalink) |
| Vista Bussiness x64 PL | Re: Power Options Corrupt (power plan unavailable) so i have tried to follow Flavius directions in post 8 however i am stomped by the last part of your direction..... the part where u say: Next choose File>>Import :choose my *.reg file,apply +restart computer When I click import on the registry editior i am confused as to what i should type as the file name.... Can u please be a bit more specific... also wat am I doing with the Power opt attachment.. when i open it where do i save it to?? The last part of the directions has me COMPLETELY stomped so hoping for a clearer response.. Thanks and much appreciation all the way from trinidad and tobago! ![]() ![]() ![]() 1.Download PSTools PsTools extract from this psexec.exe and place it in C:\Windows\System32 2.Download PowerOpt.zip and save anywhere as you whish -you can save it on your Desktop,in Documements...it's without any meaning where you save it -it's your choose. 3.Extract from PowerOpt.zip PowerOpt.reg file 4.Run cmd.exe with administrative previlliges (right click on cmd.exe as admin) and type in window: psexec -s -i -d regedit (above command will run regedit from SYSTEM account level -it is neccassary) 5.choose File>>Import ,find location where you store PowerOption.reg,choose this file,apply and next restart computer |
| | #15 (permalink) |
| Vista Ultimate | Re: Power Options Corrupt (power plan unavailable) so I have followed ur instructions.. it said registry keys were successfully imported.. i restarted, went to control panel and I am still getting he error saying "my power plan isn't available.." any other ideas? |
| | #16 (permalink) |
| Vista Bussiness x64 PL | Re: Power Options Corrupt (power plan unavailable) Run cmd.exe with administrative previlliges (right click on cmd.exe as admin) and type in window: findstr /c:"[SR]" %windir%\logs\cbs\cbs.log >%userprofile%\Desktop\sfcdetails.txt On your desktop appear sfcdetails.txt file ->attache this file to post. |
| | #17 (permalink) |
| Vista Ultimate | Re: Power Options Corrupt (power plan unavailable) yes i did try the 1st suggestion and nothing worked.. I followe dur directions. Please see the attached file. |
| | #18 (permalink) |
| Vista Bussiness x64 PL | Re: Power Options Corrupt (power plan unavailable) Strange.You have fixed all keys,there are no any errors in system files also: Run cmd.exe with administrative previlliges (right click on cmd.exe as admin) and type: powercfg -restoredefaultschemes +restart If still no effects I think you'll will have to use System Restore or Repair Install System Restore - undo Repair Install For Vista |
| | #19 (permalink) |
| Vista Ultimate | Re: Power Options Corrupt (power plan unavailable) hmmm no help with the cmd.exe. so it seems as though i will definitely have to do a system restore but this problem has been happening so long that to find a restore point that will encompass the time period is impossible.. My cd rom also isnt working so i cant reinstall everything. Is there anyway i can restore in light of my above problems?? |
| | #20 (permalink) |
| Vista 32 win 7 7600 32 bit | Re: Power Options Corrupt (power plan unavailable) hmmm no help with the cmd.exe. so it seems as though i will definitely have to do a system restore but this problem has been happening so long that to find a restore point that will encompass the time period is impossible.. My cd rom also isnt working so i cant reinstall everything. Is there anyway i can restore in light of my above problems?? Ken |
| Useful tool for power enthusiasts on the go (advanced power options) | General Discussion | |||
| Power Management/Power Options in Vista | Vista General | |||
| almost no power plan options work | Vista General | |||
| Power Plan Options | Vista account administration | |||
| Power Plan Options | Vista General | |||
