Go Back   Vista Forums > Vista Forums > General Discussion
RB
Vista - Help ...plz
10-06-2008   #1
Vista Home Premium 64-bit
Help ...plz
I have a problem with the file shell32.dll, at least I think that is the problem file.
I have several icons which once were the green/blue folder icons and now just show the "can't find icon/pic default". When you go to customize and choose icon it just shows the same "can't find icon/pic default" and if you look through the shell.dll icons there are spaces where im pretty sure the other versions of the green/blue icons were.
Any ideas????
Is it possible to replace the shell32 file?
(system repair on start-up shows no problems)
10-06-2008   #2
Re: Help ...plz
Hello Squa190, and welcome to Vista Forums.
This tutorial will help show you how to restore the personal user folder back to it's green/blue color instead of yellow.
Personal User Shell Folders
RB
