CD problem once again
prchlik
I have looked around this forum about CD problems, but no thread corresponds to my problem.
I have Vista Ultimate x64. My DVD is TSST CDDVDW SH-223F ATA.
I have a problem to read a contents of CDs. I can see DVDs, but CDs not. These CDs are originals from software producers and magazines.
Under Win XP I have no problem to read all medias. I have seen some hints, but nothing helps.
Is there somebody with any idea what is wrong in Vista?
    Intel Core 2 Quad Q9400 2,66GHz
    Asus P5Q PRO
    GEIL 4GB PC6400
    Asus EN9600GT PCI-E
    Internal
    Benq 19"
    Samsung 320GB SATA300
How old is your machine, the only thing I can think is that maybe the laser for the reading of CD's has gone bad.
Have you tried cleaning the drive at all.?
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
My machine is approx. 1 month old. So there is no reason for this problem. I am always looking for the solution, but without good result.
    Asus P5Q PRO
    GEIL 4GB PC6400
    Asus EN9600GT PCI-E
    Internal
    Benq 19"
That doesn't necessarily mean that the DVD drive isn't bad. I've known new components to fail days after installing them.
In your case, the laser for reading CDs might be bad, as Joan mentioned. It could be a dust particle or it could be out of alignment. Or it's a sub-standard drive that the manufacturers provided.
As you said, the disks work fine in other machines. To determine fully where the fault lies, try installing a DVD drive from another machine that you know reads both DVD and CD media without problems. If the problem goes away in Vista, then the original drive itself is bad and needs to be replace. If the problem persists, then the issue lies elsewhere, and we'll need to investigate further.
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
So I have made another tests. Things are getting more complicated. CD/DVD drive works perfect under other systems. It is not a hardware problem, because I can boot with a CD and then Vista cannot read the content from the same CD. I have 2DVDs from different suppliers. But both are originals. One Vista can read and the second one cannot. This is new for me, because at this moment I have no problems to read DVDs. I will test another DVD drive, but it seems that the problem has Vista. Maybe it is some security problem. Does anybody know any utility, which can catch all processes during inserting CD in the drive?
    Asus P5Q PRO
    GEIL 4GB PC6400
    Asus EN9600GT PCI-E
    Internal
    Benq 19"
Use Process Explorer and search for the handle 'cdrom' to see what is accessing your drive.
    Homebrew
    Q6600 (G0) SLACR
    Gigabyte EP35 DS3R
    2 gigs G.Skill DDR2
    XFX 8600GT
    Samsung T190 1440X900
    1440X900
    2X Seagate 120 (OS's) IDE
    1X WD 750 SATA
    Corsair HX520
    Coolmax el cheapo
So I have used another DVD drive, which is absolutely right. And the problem is same! What is worse, I have burned a CD, the burning worked very well and the CD is good. But if I put this CD in the drive, Vista doesn´t read the content. Other system like XP reads. Vista sees CD or DVD disk (the icon changes), but cannot read the content. It looks like a problem in the filesystem.
    Asus P5Q PRO
    GEIL 4GB PC6400
    Asus EN9600GT PCI-E
    Internal
    Benq 19"
Have you tried downloading and installing the latest drivers for your motherboard IDE controller (SATA controller if you have a SATA based DVD drive)? Also, what software to you have installed that may be related to the functions of the drive, such as Nero or some other such software.
Try this also:
  1. Click on the Start Orb
  2. in the Search Box, type "cmd" (without quotes)
  3. Right-click "cmd" in the search results, and then select "Run As Administrator"
  4. in the Admin Command Prompt, type "sfc /scannow" (without quotes) and press <ENTER>.
  5. If SFC reports any errors, it should fix them. If not, please report back and we can go from there.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
So exactly what happens when you try to access the CD from the drive in Explorer?
Do you get any type of error message, or any message at all?
Have you looked in your Event Viewer for any errors at the same time that you tried the CD, that may be causing this?
Have you looked in Device Manager for anything that's not working properly?
Have you done the most common repair for Optical Drives...physically uninstall the drivers, shut down and unplug the device, reboot the machine WITHOUT the drive hooked up so Windows knows it's gone, then power down and reinstall the drive, reboot and allow Windows to reinstall the drivers?
    Personal Build
    Intel E6750 Core 2 Duo
    Asus Commando MoBo (P965/ICH8R)
    4G's Crucial Ballistix Tracer DDR2 PC26400 RAM
    BFG 8800GTS OC2 320MB
    Creative Sound Blaster X-FI Platinum FATAL1TY (next)
    2 x 22" w2207 LCD Monitors
    1- 1680 x 1050, 1 - 1920 x 1080
    3 x 500G SATA II WD Caviar HDD's
    EnerMax NoiseTaker II 600W
    NZXT Lexa Classic (modified, dual doored & windowed)
    Zalman 9700 CPU cooler, 4-120mm fans, 1-90mm
    Logitech Optical Trackman trackball
    NZXT Lexa Classic Case, Zalman 9700 CPU Cooler, 2 DVD Burners c/w LightScribe (Sony, TSST), Enermax NoiseTaker II 600W PSU with Custom Chrome cable sleeving, Hauppauge HDTV TV Tuner Card, 5.1 Logitech Z5500 speakers, 15 in 1 Multi-card reader
Try this also:
Super. Here we go. This was the solution. Now I can read all CD/DVD. What is better, Vista booting is quicker approx. 3x. This command "sfc" was the right help. Thanks a lot. I don´t know this command. It has created a file CBS.log and I thought it has founded a lot of bugs (file has now 25MB). It is strange for me that there are bugs, because I am working with a pure instalation and with only few programs. But finally I am happy that it works and I can focus on other things. Thanks again.
Problem is solved. :p
    Asus P5Q PRO
    GEIL 4GB PC6400
    Asus EN9600GT PCI-E
    Internal
    Benq 19"
My optimism came too quickly. Now I have no printers, Vista cannot show System from Control Panel and other things. The command was good, but made some bad repairs. ;o( It looks that I will go in the re-installation.
    Asus P5Q PRO
    GEIL 4GB PC6400
    Asus EN9600GT PCI-E
    Internal
    Benq 19"
I have found the evil in my system. Maybe. It is UAC control. If it is disabled than the system runs with strange behaviour. if it is enabled it is better, but sometimes makes some faults too. but I need to disable UAC, because there is a lot of annoying messages, which drive me nuts. But for this I will create new thread.
Thanks a lot to everybody.
    Asus P5Q PRO
    GEIL 4GB PC6400
    Asus EN9600GT PCI-E
    Internal
    Benq 19"
I'm sorry to hear that, but this would indeed indicate that the original issue you had experienced was more deeply rooted than either of us anticipated.
If you are going the re-install route (which is always a last resort), then be cautious about what you install after reloading Windows. The most important items before any other software of any kind whatsoever would be the drivers for all your hardware. Once the hardware is happy and shows no bangs in Device Manager, then you can proceed to install application and utility software, sticking only to the essentials.
It help to only install the big ones, like Office, or the critical utilities like Nero or WinZip. Anything else is redundant. I usually only install those redundant utilities if and when I need them.
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Genius
    384kbps
In my opinion if going with a clean reinstall make sure that the first things you install before going on the internet are your firewall, or the native Vista one if you use that, and a good anti virus program. :)
    Windows 10 Home
