HELP - Parental Control Wont Open!
ThÉoPatrizi
Hi there guys, I am having a problem with the Vista Parental Control.
It just does not open when I try to open it!
It acts like I was not even trying to open.
Any idea?
Thanks for any future help!!!
    Athlon x2 4400
    Asus M2N-E SLI
    2x Kingston 1GB ddr2 667mhz
    Geforce 8500GT
    2x Seagate 250gb = 1 500gb raid-0 stripe.
You have to be logged in as an administrator level account.
    16GB DDR667
    SAS RAID
I am!
That is the strange, and I also tryed to activate the REAL Administrator account and still did not open!
Thanks.
    Athlon x2 4400
    Asus M2N-E SLI
    Geforce 8500GT
Please, some one give me help!!!
Thanks.
    Athlon x2 4400
    Asus M2N-E SLI
    Geforce 8500GT
Hello ThÉoPatrizi,
You might try running a sfc /scannow command to see if it can find and fix any bad system files that may be causing this.
If that does not help, then you can do a System Restore using a restore point dated before the problem if available.
If not, then a Repair (upgrade) install should help.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thanks a lot Brink!!!
I will sure do that!
Any further notices i'll post it here!
Thanks!
    Athlon x2 4400
    Asus M2N-E SLI
    Geforce 8500GT
