Need Help With Disk Drive Not Showing Up
Omak2008
Ok I need some help,
My Disk drive isn't showing up in the MyComputer folder, so I go to disk management and I see that it does not have a Letter associated with the drive, and when I assign one it puts it on there for about a second then takes it off. I think that it is installed correctly and everything because it knows what disk is in the tray, it just doesnt start up.
Thanks,
Omak2008
