1.    01 Dec 2008 #1
    Egypt
    Vista Home Premium 32bit
    Local Time: 01:17
    egypt
    Low Disk Space Problem
    Plz help I have Vista Home Premium running on a 320
    GB hard drive. I keep getting the low disc space on C: error message, and
    when I click on My Computer, it says I only have 189 MB of free space on the
    C: drive. However, when I click on the C drive, highlight all the folders,
    and click Properties, it says I am using 26 GB of space next to "size on
    disk". I tried to solve this problem about a week ago by moving 30 gigs of
    music to an external hard drive, but the C drive has filled up again even
    though I have not added anything to the C drive. I've also tried using disk
    cleanup and defrag, but that hasn't worked. This seems like a pretty serious
    problem. What's the deal?
    Thank you
  2.    01 Dec 2008 #2
    Texas, USA
    64-bit Windows 10 Pro
    Local Time: 18:17
    usa us oklahoma
    Re: Low Disk Space Problem
    Hello Samo, and welcome to Vista Forums.
    Vista also has a lot of hidden system files, and it reserves hard drive space for items like the virtual memory paging file and system restore.
    One main usual culprit is how much space is being used by System Restore. This tutorial will show you how to check to see how much it is using and how to adjust if you wanted to.
    System Restore - disk space
  3.    13 Dec 2008 #3
    Egypt
    Local Time: 01:17
    egypt
      Thread Starter
    thanx
  4.    13 Dec 2008 #4
    Texas, USA
    Local Time: 18:17
    usa us oklahoma
    You're welcome Samo.
Missing disk space and uninstall app problem
Hi, I have inherited an SBS server 2003 that seems to have around 4Gb of free disk space missing where as the amount used does not match the disk...
SBS Server
No free disk space error even though there is enough disk space on Windows Vista x64
Hi there, I am trying to install a software and it gives an error as Not enough disk space on C drive even though there is ample 100 gb space on...
Vista installation & setup
Disk space problem
I have WinXP SP2 installed on a Virtual PC 2007 virtual machine. On C: (primary partition; basic) I have 605 Mb free disk space which is not...
Virtual PC
I have Vista Home Premium running on a Dell Inspiron 1720 laptop with a 120 GB hard drive. I keep getting the low disc space on C: error message,...
Vista performance & maintenance
used hard disk space problem
I have partitioned a 300gb HDD so that C has 240GB and D has the remainder. C is reporting that I have used 200GB but this cannot be so as I only...
Vista General
Low Disk space problem
I am having low disk space problem in my laptop. If i am checking the size of all data in C: drive it shows 16 GB & if i am checking size of C:...
Low disk space free problem
I'm usually running low (~5GB free of 60GB) on free disk space, but I've noticed an 'odd' behaviour with Vista that has just hit as a 'critical'...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
