Hi all. I've scoured the 'net vainly for an answer to this, so I've decided to just ask it.
This seems to be common—the optical drive doesn't work. I'd like to detail more symptoms, though, that might help form a real fix for those whom the solution at The CD drive or the DVD drive does not work as expected on a computer that you upgraded to Windows Vista wouldn't work, as it didn't for me (Upperfilter and Lowerfilter values don't exist in my registry).
Thanks for the help! I hope this extra information is helpful, too.
- Upon a clean installation of Vista, the optical drive works fine. After installing the whole slew of current updates, it stops working. I didn't figure this was a thread for the Windows Updates forum, though.
- When putting in a disc, the drive goes to work (illuminated busy light and the sound of the drive spinning) for a bit, then turns off and on continuously, freezing the computer until the disc is ejected.
- A disc left in the drive upon start-up will work correctly. Once I open the drive, however, that's when it no longer works, whether I load the same or different disc.
