Hello, i am owning vista ultimate x64. with core 2 duo e8400 3GHz & 2.83 GHZ.
always, when i was checking the computer properties i saw this written: intel core 2 duo e8400 3GHz & 2.83 GHZ.
anyway, last night i made an overlcock from 2.83 ghz to 3.2 ghz, when i entered after the OC to the computer properties i saw that the computer has changed to 3GHZ & 3.2GHz.
then i set the cpu speed back to the normal speed (normal fsb) and then when i checked system properties i saw 3GHz & 2.66 GHz.
it was really strange because cpu-z and other programs showed me that i am using 2.83 ghz and not 2.66.
anyway, i tried to fix it and i did again overclock to 3.2 ghz.
but then, when i started the computer again and clicked on system properties, i saw still Intel core 2 duo e8400 3GHz & 2.66 GHZ, but cpu-z and some other programs showed me that i have 3200 mhz.
so my question is this:
why vista is not showing my actual bus speed and cpu speed and it's showing wrong cpu speed.
my second question is:
even if the cpu's speed is not written on the computer properties, as long as it's written on cpu-z and other programs that i have 3200 mhz, the computer will use it, right? or it will use just the 2.66 ghz that is written on vista?
sorry for my poor english, hope you will answer me
Yours,
Roy.:huh:
Yours,
Roy.:huh:
- Intel Core 2 Duo 38400 3.0Ghz 6MB Cache S775 1333Mhz
- EP45C-DS3R
- Kingston HyperX 2x2GB DDR2 1066Mhz PC2-8500
- Graphics Card(s)
- Gigabyte 9600GT 512MB GDDR3 DX10 HDTV 2XDVI PCI-E
- Cooling
- Arctic Cooling Alpine 7 Pro CPU Fan For s775
