Hello
I have recently installed vista ultimate x64 on a new machine:
GA-MA770-S3
Athlon X64 5400+
4 GB kingston 1066
Everything is perfect except a terrible problem with my
usb2 sticks. I cant copy large files ( > 500 MB) to any of them.
All the sticks are formatted to FAT32 and working perfectly to
other machines with xp installed. Never had any problem with them.
Vista starts copying the file to the usb. After a while (40 - 50%) it stops for a
minute or two and then an error displays saying something like
file c:\documents ....\filename no longer exists. The led on my usb
stick continues to blink like crazy and it stops blinking only if i remove it
no matter how long I wait (hours).
This does not happen with small files. Also in event log I see something
about an error during a caching operation.
I have tried the following:
I reformatted my sticks to ntfs. Same problem
I have checked "optimize for performance". Same problem
I have installed all updates from microsoft. I also googled a lot
and I have found similar problems but no solution.
Any help please? I dont want to go back to XP since I loved this new OS.
Thanks.
GA-MA770-S3
Athlon X64 5400+
4 GB kingston 1066
Thanks.
