| 32 vista basic | help - product key number Can i use the product key from my vista basic for my premium disc? did have product key when bought the premium disc but have lost it? stupid! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: help - product key number Hello Gordonm, and welcome to Vista Forums. If this is a retail Vista installation DVD, then you can use the Premium disc to install Basic with your product key number. You can only install the edition of Vista that the product key number is for. You will not be able to install Premium with the poduct key number for Basic. ![]() Hope this helps, Shawn |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: help - product key number Hi gordonm and welcome to Vista Forums ![]() Yes, you will be able to use the product key on the other disk. However, since it is a BASIC key, you will only be able to use it for that version (either 32-bit or 64-bit). This is similar to what I did when setting up my system to multi-boot. I had an original Home Premium disk (without SP1), but I then subsequently got the Ultimate version (with SP1, both 32-bit and 64-bit). I used the Ultimate key with the 64-bit disk and the Home Premium key with the 32-bit disk, although I could only install the Home Premium version with it (obviously). This is because all disks contain all versions of Vista, and it is the product key used which determines which version is installed. |
| product number | Vista mail | |||
| Product Key Number | Tutorials | |||
| Product ID Number incorrect ? | Vista account administration | |||
| Product ID Number | Vista mail | |||
| Product Number | Vista installation & setup | |||
