rsvr85
I need to recover my HP PC to it's original factory state. I've done it before with no problems.
However, this time i recieve a message saying this;
http://i330.photobucket.com/albums/l406/rsvr85/1.jpg
There is a recovery partition on my PC and it's healthy but why won't my system detect it?
http://i330.photobucket.com/albums/l406/rsvr85/2.jpg
I wiped another partition on my HDD with W7 installed on it, is there any way this could have caused this problem?
My DVD drive doesn't like burning disks either so a recovery CD is out the question, is there any way i can mount the image to a virtual drive and use a USB stick?
Thanks for any help
P.S The recovery partition isn't marked as active, should i mark it so or leave it? Windows warns me that if i mark it so and there isn't an OS on it, my PC might fail.
My other USB sticks are marked as active and they don't have an OS on them, is it safe to do this?
Thanks for any help
- HP Touchsmart IQ771.uk
- 1.80 gigahertz AMD Turion 64 X2
- ASUSTeK Computer INC. PHOENIX 1.xx
- 2GB
- Graphics Card(s)
- NVIDIA GeForce Go 7600
- 1440x900
