Go Back   Vista Forums > Vista Forums > General Discussion
Vista - usb to rs232 cable install problems
Old 02-20-2009   #1 (permalink)
Vista Home Premium
I can't get my usb to rs232 cable to install and vista keeps indexing the com port as it trys the next install. I have downloaded the driver, updated the driver, deleted the driver and reloaded the driver to no avail. Now it shows 26 com ports in use and tells me the device I am trying to install is trying to use a display name that is already in use. How do I clear this up so I can install this device?
Communicating with RS232 (USB) Ports VB Script
usb to rs232 converter Vista hardware & devices
RS232 COM-Port handler VB Script
RS232 and Media Center Media Center
Problems connecting Sony to Mitsubishi HD TV via VGA extension cable Network & Sharing
