Hello,
I need some help configuring Vista environment variables.
Changes in the 'path' under system and user variables don't seem to reflect.
1) My 'path' variable under system variables looks like:
%SYSTEMROOT%\SYSTEM32;%SYSTEMROOT%;%SYSTEMROOT%\SYSTEM32\WBEM; C:\Program Files\kepler-1.0.0\R\R-2.6.2\bin; \Program Files\Java\jdk1.5.0_15\bin; C:\Program Files\apache-ant-1.7.1-bin\apache-ant-1.7.1\bin
Despite this: When I type java -version, I get java version "1.6.0_02" as the reply, while there is no trace of this version anywhere in the environment variables.
Neither does ant -version give any response..when infact it should give the version.
2) I am trying to run R (executable file present in the bin), which is not running despite adding
C:\Program Files\kepler-1.0.0\R\R-2.6.2\bin to the path variable.
3) I was confused where to add the path variable, so I've added it to both user and system variables.
I'll be extremely greatful if anyone can solve this perplexing issue!
Thanks a ton!
Thanks a ton!
