Sleep Mode Problem
  1. #1
    Newbie
    Vista Home Premium 32bit
    Local Time: 12:16 AM
    Sleep Mode Problem
    I ran a search on Google and found this website's tutorial on fixing a Sleep mode problem, but unfortunately none of the steps helped.
    My particular problem isn't that something wakes the computer back up (that problem was actually fixed using your methods), but rather that my screen goes black and my computer keeps running.
    My previous computer used sleep mode fine, but I just got a new motherboard (Asus P5N-D), case, and processor (Intel Core 2 Quad), so it's no mystery why it doesn't work anymore, I just can't figure out how to restore the option.
    I know it isn't a crucial feature of Vista, but I prefer using it over a complete Shut Down, and if you have any suggestions, I would really appreciate it.
  2. #2
    Brink's Avatar
    Administrator
    Texas, USA
    64-bit Vista Ultimate SP2, Windows 7 Ultimate SP1, Windows 8 Enterprise
    Local Time: 11:16 PM
    usa us texas
    Re: Sleep Mode Problem
    Hello Ajburr, and welcome to Vista Forums.
    Double check the Power Plan Options to make sure that the Multimedia Setting is set to "Allow the computer to sleep" as recommended in Step Two of the tutorial below.
    Power Options and Sleep Mode Problems
    If that does not help, then check your BIOS sleep state (Step Three) to see if that may be causing this.
    Hope this helps for now,
  3. #3
    Newbie
      Thread Starter
    Well I did change the Multimedia Setting but that still had no effect. I also checked BIOS and made sure S1 and S3 were active.
    I honestly have no idea what else to try.
  4. #4
    Brink's Avatar
    Administrator
    Texas, USA
    usa us texas
    Check to make sure that you have the latest motherboard chipset drivers and BIOS installed. Here is the link for you motherboard's website. You will need to enter:
    Product: Motherboard
    Series: Socket775
    Model: P5N-D
    Click on Search
    Select Vista 32-bit
    ASUSTeK Computer Inc.-Support-
  5. #5
    Newbie
      Thread Starter
    Well, it works now, LOL. I'm not entirely sure why, but I think that after I changed the Multimedia Setting, and then went into BIOS and changed it from just S1 to both S1 and S3, it solved the problem.
    Now the only problem is that when I put it to sleep, my mouse doesn't wake up, LOL. I'll have to check the driver for that.
  6. #6
    Brink's Avatar
    Administrator
    Texas, USA
    usa us texas
    That's good news so far.
  7. #7
    ferrisits's Avatar
    India
    Vista Home Premium
    Local Time: 10:16 PM
    india
    Ensure that you have the mouse setting, set to wake the computer from sleepmode.
    Stop Your Mouse From Waking Up Your Computer
    Eusure you have the option checked .
  8. #8
    Newbie
      Thread Starter
    Okay, it's all good now The trick is that when I wake up the computer I have to click the mouse and tap the keyboard to make sure they both wake up too. Can't complain really
  9. #9
    Brink's Avatar
    Administrator
    Texas, USA
    usa us texas
    Ajburr, I'm happy to hear that you got it sorted.
Sleep Mode Problem problems?
sleep mode problem Suzanna General Discussion 4 29 Nov 2009
Problem with Sleep Mode Space General Discussion 12 31 Aug 2008
Sleep Mode Problem Jerry Vista General 1 18 Dec 2007
Sleep mode problem Lasser General Discussion 8 13 Oct 2007
BIG SLEEP MODE PROBLEM Fritz Vista performance & maintenance 7 24 May 2007
