Go Back   Vista Forums > Vista Forums > General Discussion
Vista - USB Bluetooth adapter problems
Old 04-03-2009   #1 (permalink)
Vista Ultimate x64
I have a Zoom USB bluetooth adapter (model 4322) installed with the included Bluesoleil software and drivers. I am using this with a logitech bluetooth mouse model v470 and Vista ultimate x64 with SP1 and all updates installed. When the mouse is not in use for about 30 seconds it disconnects. I try moving the mouse to wake up/ reconnect and there is a long pause (@ 15 seconds) before I am able to use it again. The mouse works normally on another system and another bluetooth mouse exibits the same symptoms. I have disable the power management in the drivers of the USB port but still the problem persists. Can anyone suggest anything sle which might help? Zoom Tech support has been responsive but the problem is really getting top be annoying
Bluetooth adapter Drivers
where do i put the bluetooth adapter????? Network & Sharing
bluetooth adapter Vista General
Bluetooth usb adapter ES-388 V2.0 Vista hardware & devices
Bluetooth USB Adapter Vista hardware & devices
