Help, Changing from basic theme to areo.
bangu
So. The little bubble popped up and said "some program isnt compatible with areo, You need to switch to basic" So, I cant find out how to switch back to areo. help?
Hello Bangu, and welcome to Vista Forums.
You can change back to the Windows Aero color scheme in the Advanced Appearance settings. :)
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Whenever I have run a program that is not compatible with Aero, it automatically switches to the Basic scheme. When I close the said program, the system automatically switches back to Aero.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
