I did a clean install with VISTA ULTIMATE (same program as-was). I have been trying to figure out all day why the USB laser jet printer will not print. It is supposed to 'see and install a USB printer when switched on', but it won't. Nothing was changed on the hardware hook-up since it worked fine on the previous VISTA O/S.
I know this is got to be a simple fix, but danged if I can figure it out?
- self-constructed
- 3.10 gigahertz AMD Athlon 64 X2 Dual Core
- Gigabyte GA-MA78G-DS3H
- 4Gb Corsair
- Graphics Card(s)
- HIS 8450
- AMD 780G onboard
- DELL 2405FPW
- 2) WDC WD6400AAKS-00A7B2 640Gb
- a 'couple clicks faster than smoke signals
