Solved Slow startup problem
mq15
Hi there,
I purchased my system (Laptop, dual core HP Paviolion dv6700) and installed vista home premium in December 2008. In the beginning system's performance was good but now (within 6 months) it starts so slow. What may be the problem. Please help me.
Regards.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
Thanks a lot Shawn. The help you made is praiseworthy.
I still ask that what are the reasons that a system becomes slow.
Thanks again Shawn.
Theres a few reasons a pc becomes slow:
  • Youv installed more programes that autostart with windows
  • you update your programes and they then require more resources
  • you have had spyware or viruses on your pc
  • you havent defragged
  • etc
Theres loads of reasons why it slow down but the most common are the ones above. Hopes this helps you :)
You're welcome Mq15. :)
Stew as pretty much listed the most common reasons why.
