fullgrownnut
I have a Compaq Presario desk top computer, and my wife has basically the same computer as mine (also a Compaq Presario), but in lap top form. Hers is about a year newer than mine. My computer came with 1GB or RAM, and I installed another 1.5GB about a year ago (by replacing one of the two 512mb memory cards with a 2gb card), and now I have a total of 2.5GB of RAM. My computer model, according to Compaq, is expandable up to 4GB.
In the last month or so, I've got into using DVD ripping programs to abstract video from discs and into my computer. Using Roxio at first, a 25 minute television show was taking about three hours to complete, with a video file of only 578MB being produced. On this particular program, there is no settings to produce a smaller or larger file. I have to say that the DVD rips were coming out just as good as the DVD version when I played back the "wmv" file in my computer, so I was very pleased with that, at least.
The problem I'm having is this... when I run this Roxio program, it takes up 100% of my CPU usage, and boggs down my computer's speed to slower than death to the point that it makes it very hard to do any other activities at the time. I then did a little experiment using my wife's computer. Since I couldn't install the Roxio program in her computer (it just came with my computer), I installed a trial version of Xilisoft DVD Ripper Ultimate 5 into hers, then tried ripping the same 25 minute television episodes from the same DVD. It only took about 15 minutes to produce a file just a tad bit smaller than with my Roxio program. While this program was ripping the DVD, I noticed that the CPU usage on her computer was working between 30%-40% and I was also able to run other additional applications with hardly any indication of it being slowed down. I then installed the SAME exact Xilisoft program into my computer, and attempted to rip the same exact 25 minute tv program, however instead of only a 15 minute ETA like on my wife's pc, the program was giving me an ETA of almost 3 hours!... AND with 100% CPU usage. This is WITHOUT running any additional applications other than what's just running in the background (and by the way, I am strict on which programs are running at Start-up by controlling that in the msconfig utility tool... I only run what's absolutely necessary at Start-up).
I'm concerned about this because I have 1/2GB of RAM more in my PC than in my wife's, but hers is obviously running more efficiently than mine. What could be causing this??? I'm starting to think that maybe the 2GB memory card I installed a little over a year ago is defective or something. And by the way, yes my computer is registering the additional RAM in it's own specs (here is a screen shot of my System Specs):
Can anyone shed some light on why my system is running so much slower/less efficiently than my wife's computer's even though I have more RAM installed in mine? I'm also thinking that it could be a processor related issue, but for the same job to take over two hours more on my computer than on hers just doesn't make any sense at all, and seems to be deeper than that. Thanks for your help.
Edit: Additional information to clear up any questions about this:
When I ran the Xilisoft program on my computer, and WHILE it was in the process of ripping (with no additional applications opened up), I brought up the Performance tab in the Task Manager utility, and it was showing that my RAM usage was at 1.25GB, which is exactly HALF of my RAM, and still left me with an additional 1.25GB remaining to be used. So in other words, it's not like this program is using all of my RAM, or even close to it because even when my system is at idle, with no additional applications even opened, the Performance tab in the Task Manager shows a level of 0.96GB or RAM being used. If you do the math, that means that the Xilisoft program is using 0.29GB of RAM or 290mb. However, like I explained above, the CPU usage is running at 100% constantly while this application is running and doing its thing.
Also, I just installed a small program which tests your processor's speed, and after I tested it, the results showed 2411mhz or 2.411ghz, so it looks like my processor is running like it should.
