System Restore Help
I have read the tutorial on how to see how much space is allocated for system restore and i was wondering if i mine seems a little high to anyone.
Hi, it depends on how much space is occupied on system disk.
    AMD Athlon 64 X2 6400+
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    1280x1024@32bit@75MHz
    1 x Seagate 120GB SATA (OS installation)
    1 x Seagate 200GB SATA
    2 x Seagate 320GB SATA (Hardware RAID 0)
    1 x Seagate 250GB IDE (in external USB box)
    1 x TrekStor 750GB USB
    650W
    Logitech Cordless Desktop EX 100
    Logitech Cordless Optical
    8192 kbps / 640 kbps
In my opinion, one partition is faster than two.
And you could have problems if you reinstall Vista on the first partition in the future: being present another partition, Vista will assign letter C: to this, and letter D: to new partition, no matter if it is the first. So your system will be installed in D:.
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
Sorry, are you planning to divide you C: partition?
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
Hello Georgiaboy,
He meant if your were planing on shrinking the C: drive to create a new partition with.
http://www.vistax64.com/tutorials/95398-disk-management-shrink-partition.html
You would be fine be cutting the amount of disk space used by System Restore if you like. Just remember, the less space that you have set, the less restore points that can be stored in case you needed them. With that said, I think no more than 15 GB is enough depending on how much you change and install stuff on your computer and your needs.
    1TB Samsung 990 PRO M.2,
    4TB Samsung 990 PRO PRO M.2,
    Galaxy S23 Plus phone
That should be plenty. :)
Excuse me, I didn't understand. Now I understand...
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
Yes, so free space fragments are placed one close another.
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    HP Enhansed Multimedia
    Razer Diamondback 3G
    18.6Mb/s
    My First Build ;)
