Re-start problem.
kfreire
Hi:
I would like to know if someone else has the same problem.
When I try to re-start Windows , the computer shuts down and try to start but instead beeps three times and don't start , then I have to press the power button to shut it down and wait about 10 minutes before starting again .
I have Windows Vista x64 on an Asus P6T Deluxe Intel X58 motherboard with 12GB RAM and an Intel i7 Extreme processor 965 with a Sceptre widescreen 22" monitor and a Thermaltake V1 cooling Fan with 800 watts power supply.
Thanks, kfreire.
    Gamer Paladin F950
    Intel Core i7 Extreme 965 (4 x 3.2 GHz/8 MB L3 Cache)
    ASUS P6T Deluxe Intel X58
    12 GB [2 GB X6] DDR3-1333 Corsair
    NVIDIA GeForce GTX 280 1 GB
    SoundMax Integrated digital HD
    Sceptre LCD 22" Widescreen
    1680x1050x60
    1 TB Hard drive
    800 watts -XION SuperNova
    Nzxt Guardian921 Gaming tower case
    Thermaltake V1 CPU Cooling fan System
    Logitech G11
    Logitech wireless
    Cable modem
    CD/DVD Driver- LG GGW H20L Blu-Ray Re-writer & DVD-R/+RW Burner.
Did you change anything in the BIOS?
Try re setting the BIOS and see what happens. I am running a very similare configuration and it runs perfectly. I have the 920 processor over clocked to 3.4G and it runs perfectly.
The beeps are coming from a BIOS start error.
Are the three beep long or short? Or a combination of long and short?
    AMD Athlon 64 X2 6400+
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    1280x1024@32bit@75MHz
    1 x Seagate 120GB SATA (OS installation)
    1 x Seagate 200GB SATA
    2 x Seagate 320GB SATA (Hardware RAID 0)
    1 x Seagate 250GB IDE (in external USB box)
    1 x TrekStor 750GB USB
    650W
    Logitech Cordless Desktop EX 100
    Logitech Cordless Optical
    8192 kbps / 640 kbps
The beeps are 3 long beeps...
Battman...How do I re-set the BIOS (sorry for the dumb question, don't want to screw up anything). I have never messed around the BIOS before.
Thanks.
    Gamer Paladin F950
    1680x1050x60
    1 TB Hard drive
    Logitech G11
    Logitech wireless
    Cable modem
If you want to re-set the bios you need to boot in to the bios and reset it from there. When in the bios most resets are F5, F10 to save and exit. Check to see if there is a CMOS reset button at the rear of you computer, most Asus boards have them, it would be even easier to use that. What version bios do have ?, if you need to update the bios use the Asus E-Z flash in the bios, dont use the Asus software tool where you update from Windows. Download the latest bios from Asus and save it to a mem stick, connect to a usb port and boot in to bios, go to E-Z flash and follow onscreen instructions, but be warned, you should never take the update of the bios lightly, it can be fraught with danger, but if you follow the on screen instructions you should be fine. I cant say for sure if this will fix it but it does sound like a motherboard problem or at least hardware. Here is the link for Asus, it's the forum for your motherboard, you may find somebody else has had the same problem and has a fix for it, you can get your bios there too. Go to gownloads. Good luck.
http://vip.asus.com/forum/topic.aspx?board_id=1&model=P6T+Deluxe&SLanguage=en-us
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    150 Gig WD Raptor
    300 Gig Maxtor
    300 Gig Maxtor, (External)
    CoolerMaster 1000
    Logitech G15
    Logitech G5
    20Mbps
Thanks Stoney, I'll take a look at ASUS website.
    Gamer Paladin F950
    1680x1050x60
    1 TB Hard drive
    Logitech G11
    Logitech wireless
    Cable modem
3 longs beeps states for RAM errors.
    Asus M2N-E SLI
    2 x NVidia 8600 GTS
    Integrated CM-6501
    Benq 19" + LG 17"
    650W
