| Vista Ultimate x64 | Right click menu on a drive open option is not default Hi..Ca anyone help me....When I right click a drive on my Vista..it shows explore as the default option and is highlighted than the open....I check for trojans and viru but none were found...can anyone plz help me to fix this...any help will be greatly appreciated!!! |
| Vista Bussiness x64 PL | Re: Right click menu on a drive open option is not default You have trojan,use this tool Malwarebytes.org |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Right click menu on a drive open option is not default Hello Saurabhmal, and welcome to Vista Forums. This may be able to help with this. Explore is the default option to open it in the same window. and Open is to open it in a seperate window. Open a Folder in the Same or Separate New Window Hope this helps, Shawn |
| Vista Ultimate x64 | Re: Right click menu on a drive open option is not default Ok...So correct me if I am wrong.....By default in Vista x64 Explore is the default option when right clicked on any drive in MyComputer so i need no to worry about any virus and Trojans....anyways I scanned my PC many times with nod32 and Malwarebytes and found nothing!!! |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Right click menu on a drive open option is not default Correct. Explore is the default to open the folder or drive in the same window. No need to worry about it. You can change it to where Open is the default if you like in the link above to have a drive or folder open in a separate window by default instead. |
| | #6 (permalink) |
| Vista Ultimate x64 | Re: Right click menu on a drive open option is not default Ok I got it,I was worried because I had connected an external with the sality virus ion it..I think Nod32 was able to prevent it into entering in my PC....thanks a lot dude.... |
| | #7 (permalink) |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Right click menu on a drive open option is not default You're welcome. |
| right-click menu search option | Vista file management | |||
| Re: Windows Explorer Explore option is gone from right-click menu | Vista General | |||
| Problem with right click 'open with' menu and images | Vista General | |||
| How do I change double click from SEARCH to OPEN on drop down menu | Vista file management | |||
| Default Start Menu option missing from Taskbar & Start Menu properties screen | Vista General | |||
