Go Back   Vista Forums > Vista Forums > General Discussion
Vista - Dvd/cd will not work
Old 07-04-2009   #1 (permalink)
64 bit vista home premium
Ever since I burned a movie to a dvd my dvd/cd drive will not allow me to watch a movie or listen to a music cd. When I insert a movie dvd my computer does not recogonize it. I go under my computer to my dvd drive and try to open it and it ejects the disk and says please insert a disk. If I insert a blank dvd +rw it recogonizes it. It is like my computer dvd/cd drive is in a permanent burn mode, not a read mode. I have uninstalled my dvd driver and reinstalled my dvd driver. Still same problem. I would appreciate any help. Thanks
Old 07-04-2009   #2 (permalink)
Windows 7 x64 build 7100 & Ubuntu 9.04
Re: Dvd/cd will not work
Hello Packerfan1969, welcome.
Go into Device Manager, and find your DVD drive. Select Roll Back Driver. This might fix your problem.
~Lordbob
Old 07-04-2009   #3 (permalink)
Thanks. I tried to do this but my Roll Back Driver is not highlighted and will not let me click on it.
Old 07-04-2009   #4 (permalink)
Vista Bussiness x64 PL
Try update driver for dvd
if no help Look this:
Quote:
1.Make sure the service Shell Hardware Detection is started and set to AUTO
2.Navigate to key HKLM\System\CurrentControlSet\Services\Cdrom and check you have phrase Autorun =1,if is 0 fix it + restart
3.Check also this ->DVD Drive Icon Disappeared from Computer - Fix
4.If everything fail download FrogAspi Frog Aspi - the FREE wnaspi32.dll replacement
place wnaspi32.dll in C:\Windows\SYSWOW64 again uninstall DVD driver + restart
Old 07-04-2009   #5 (permalink)
Vista home premium 32bit
speakers randomly wont work sometimes on laptop but external will sometime work Sound & Audio
Still searching for way to get Vista search to work: Why doesn't FilterFilesWithUnknownExtensions registry key work in Vista? Vista General
all cd's don't work, but dvd's still work Vista hardware & devices
HP LaserJet 1010 don't work in Vista since Beta2 - Advanced 1384 Printing Support drivers for XP don't work Vista print fax & scan
Will all the programs that work on xp work on vista? Vista General
