My problem:
When I try to extend H: or even when I try to create a new simple volume with the unallocated space, it takes me through the wizard but when it's time to 'finish' I get this -
"The operation you selected will convert the selected basic disk(s) to dynamic disk(s). If you convert the disk(s) to dynamic, you will not be able to start installed operating systems from any volume on the disk(s) (except the current boot volume). Are you sure you want to continue?"
Whether I click 'Ok' or 'Cancel' I get the same result which is nothing! Please help! What do I do? I have unusable 100 gigs of storage sitting there
