Vista or software conflict... please help
I have a problem with Vista I would either love some help with or some help with restoring to a previous point.
Somehow, there is a system (presumeably software) conflict of some type that will no longer let several of my software applications (itunes, quickbook, quicken, etc) connect to the internet. Specifically, itunes can connect to the internet, but when I try to connect to the store, I get an error message (-9812). Same with Quicken when we try to connect securely to banks. This is a problem specifically b/c I can no longer sync my iphone.
I have uninstalled my Norton internet security, turned off the firewall, made sure all the software has exceptions w/in the firewall with it on, made sure the date/time clock is correct, changed internet explorer security, disabled as many programs (in attempt to get arround any conflicts) and restarted the computer in safe mode all without success. I also cleared out my host file, but that didn't work either. My older laptop with windows xp and my two iphones are having no such connection issues. So therefor, I'm fairly certain it's a windows or software issue of some type.
I've searched everything, tried as much as I know to do. My next best solution was to maybe do a system restore to a prior timepoint, but using the system restore feature within windows, it only gives me a weeks worth of dates to choose from... I need to go back like 1-2 months now.
Does anyone have a solution or another method to go back in time without completely starting from scratch? (I have a dell that will let me restore back to factory settings).
One other option I considered was upgrading to windows 7 as it might solve my problem and allow me to keep all my settings. Opinions on this option?
Thanks in advance.
Doug in Denver
Thanks in advance.
Doug in Denver
